How to Make an Acrylic Ring With Corian
Intro: How to Make an Acrylic Ring With Corian
In this tutorial I will show you my process for making rings from plastics or acrylics.
For this project I used Corian, which is a brand name for a solid surface material created by Dupont.
It is composed partly of acrylic and is easy to work with wood working tools.
There are many different colour variations and I used “Mardi Gras” as it looks pretty cool!
These sample blanks are 50mm square and 12mm thick.
Where to find Corian:
Corian is widely available and inexpensive off-cuts or samples can often be found on Ebay. I've included links to Ebay suppliers of Corian below*:
*I am a member of the Ebay partner network so by using my link to make a purchase you help me to keep creating awesome tutorials!
STEP 1: Marking and Drilling a Hole
Start by marking roughly where to drill a hole. Marking off to the corner gives a good chance of getting two rings from one blank.
Using a drill bit slightly smaller than the required size, drill a hole on the drill press.
STEP 2: Cutting on the Scrollsaw
Next mark a rough circle around the hole (I did this by tracing around a socket) and cut the shape out on the scroll saw.
STEP 3: Sizing the Hole and Polishing Edges & Inside
Mount the ring in a 4 jaw chuck and start sanding the outer edges and inside of the ring
Work methodically through the grits of sandpaper to a progressively finer grit. In the video I wet sanded through 150-12,000 grit.
Gradually bring the inside diameter to the required size and when one edge is finished, flip the ring around and repeat the process on the other side.
STEP 4: Shaping the Outside
When the edges and inside are polished mount the ring on a jamb chuck.
I also used a wine cork in the tailstock in may lathe to hold the ring in place.
True the ring by making it round with a roughing gouge and then move to a skew or scraper to create an even finish.
STEP 5: Final Shaping & Polishing
Swap to mounting the ring onto a mandrel for final shaping and polishing.
Wet sand the ring as before working through progressively finer grits. Create a smooth shiny surface with no tooling marks.
With sanding complete turn up the speed on the lathe and buff with a car polishing compund. Rub the compound in and buff out with a lint free cloth.
Clean off any remaining polishing compound and take some nice pictures!
STEP 6: Photograph It, Wear It or Sell It!
Thank you for checking out my tutorial!
I hope you enjoyed watching and reading about the creation of this beautiful Corian ring!
To watch more instructional videos please subscribe to my Youtube channel as I post there more frequently:
https://www.youtube.com/channel/UCngHVOU8ZgkDMZKLc...
You can find more of my work over at:
26 Comments
warriorethos2 8 years ago
ZebranoWoodCraft, your instructable on making acrylic rings with Corian is easy to follow especially with the video that you provided. Well done and good luck in the jewelry contest.
ZebranoWoodCraft 8 years ago
Thank you!
Battlespeed 8 years ago
Interesting process but I'd use different material - that ring still looks like it was made from a kitchen countertop to me.
Kiteman 8 years ago
That's because it is...
Thejesterqueen 8 years ago
maria_AI 8 years ago
looks amazing :)
thundrepance 8 years ago
i fell in love with corian decades ago ~ for counters .... this makes it that much better! the finished product is just BEAUTIFUL x^)
inchman 8 years ago
Great 'ible and excellent idea for your jamb chuck! I do have a question, how strong is the finished ring? I have made many rings from wood and other composites, but they seem to be too frail to wear everyday. Any idea how strong the Corian is?
Thanks again!
Thank you! The corian ring is very strong, think it would be hard to break under normal everyday wear. Maybe I should test one to destruction haha!
world of woodcraft 8 years ago
nice work fella. im now going to hunt for corian
Awesome, thank you! Ebay is a great place to start!
tomatoskins 8 years ago
This is amazing! Where did you get your samples of Corian? I've never heard of it before and looks like fun stuff to work with. I've made my fair share of rings before but yours look spectacular!
KevinA5 8 years ago
You can actually pick up FREE samples from Home Depot or Lowes. They are totally free and they usually have a decent variety. I used to get tons of them to practice laser engraving. They are there to be taken home by potential customers shopping for countertop renovations.
KevinA5 8 years ago
No problem. They actually tend to have a real nice variety, but I would check Lowes and Home Depot b/c you may find different things there.
Thank you! I got the Corian samples from a wood working show a while back but offcuts and samples are readily available on Ebay or at most wood turning suppliers.
