How to Make an EMP Jammer
Intro: How to Make an EMP Jammer
An electromagnetic pulse (EMP), also sometimes called a transient electromagnetic disturbance, is a short burst of electromagnetic energy. Such a pulse may occur in the form of a radiated electric or magnetic field or conducted electrical current depending on the source. EMP Jammer is a device capable of generating a transient electromagnetic disturbance that radiates outward from its epicenter, disrupting electronic devices.For more information about EMP jammer check this out.
For more projects subscribe my youtube channel [Click Here]
Now I am going to instruct how to make an EMP Jammer with less number of components.
Let's Get Started...
STEP 1: Components Required
STEP 2: Circuiting
1. Take out the circuit out of the mosquito zapper.
2. Make a coil of 3-4 turns of hookup wire.
3. Solder one wire of coil to the anyone terminal of capacitor at output.
4. Glue another wire of coil near the another terminal of the capacitor at a distance of 2 mm or less than it.This is to create a spark gap.
5. Solder wire to circuit activating switch to extend the switch out of the case.
6. Place the circuit in the case carefully and turn on the circuit and close the case.
7. Apply glue on the case then fix the switch and solder activating switch extending wire to it.
8. Now apply a piece double sided tape to case and fix the battery.
Here the circuit construction completed.
For detailed construction check the video below.
Note : While using this device, keep your electronic devices away , because it may damage you device. I will not recommended to use it. I made this for educational purpose only.
Keep this device away from people who were installed with pacemaker,stunts.
Usage of this kind of devices is not allowed in some countries, make sure your countries policies before making this device.
STEP 3: Construction and Testing
Feel free to comment.
24 Comments
Usernamecp 3 years ago
yesssiknowhaw 3 years ago
morriganmcteag 7 years ago
JunezRiyaz 7 years ago
Thanks for your info, I updated in instructable.
thematthatter 7 years ago
Monetary Penalties Can Exceed $100,000
per violation. Violations of the jamming prohibition can lead to
substantial monetary penalties (up to $122,500 for any single act),
seizure of the illegal jammer, and criminal sanctions including
imprisonment.
xavierbarthies 3 years ago
naveennani8004 3 years ago
letmeon 3 years ago
MartinJ11 7 years ago
My device works around 15cm distance effectively.
Working range depends on spark gap.
letmeon 3 years ago
parthkorat001 6 years ago
NilanjanS6 6 years ago
how to prevent this high voltage emp
a95123hsu 7 years ago
can you give me the length, width and height of the adapter case. thank you!
ecrouch 7 years ago
What factors are involved in the design of the coil? For example, why did you choose the number of turns that you did? Why that diameter?
Random Gadget Hacks 7 years ago
who cares
vexvoltage 7 years ago
henrique12345 7 years ago
I am just curious to know and was wanting to ask a question. Places like libraries, schools and cinemas have jammers that block signals from cell phones. If there is a security alarm in a library that is cellular based and a thief decides to break in, wont the jammer prevent the alarms signal from sending?
Oncer 7 years ago
I've said it on other instructables for similar devices but this is just a weapon that could seriously injure or kill someone whom is reliant on an electronic regulatory device such as a pacemaker. It's as simple as that.
