How to Make an Easy No Bake S'mores Tart
924
39
4
Introduction: How to Make an Easy No Bake S'mores Tart
About: Helping you create great food with easy to follow step by step recipes. Check out www.kitchenmason.com for more marvelous ideas!
I’m starting the new year how I mean to go on. I’m all for eating healthy but seriously, just look at that!! How much do you want to bury your face in it right NOW?! I promise this S’mores Tart is nowhere near as complicated as it looks to make either. In fact, it takes less than 30 minutes and you don’t even have to switch your oven on. I’m not lying I promise! If you’re on a diet, sorry, you’ve come to the wrong place…
Here is what you will need to serve 8-10.
For the Base
  • 300g Golden Oreos
  • 100g Unsalted Butter
For the Filling
  • 200g Dark Chocolate, Finely Chopped
  • 55g Unsalted Butter, Cubed & Room Temp
  • 200ml Double Cream
For the Decoration
  • Plenty of White Marshmallows
  • 1 tbsp Milk Chocolate Chips
  • 50g Dark Chocolate
Essential Equipment
  • 4 x 14″ (10 x 35cm) Fluted Loose Bottomed Rectangular Tart Tin
  • Food Processor
  • Blow Torch (Optional)
Step 1: To Make the Base
Firstly, tip all excluding 3 of your Golden Oreos into the food processor (fillings too) and pulse until it becomes fine crumbs. Put those 3 Golden Oreos to one side for the decoration later.
Then melt the butter either in a small saucepan over a low heat or in a small bowl in the microwave in 15 second bursts stirring between each time. Pour the butter into the food processor and pulse again until it’s a bit like wet sand.
Step 2: To Make the Base
Tip this into your tart tin and press firmly into the base & up the sides with a metal spoon.
Pop into the freezer to firm up while we make the filling.
Step 3: To Make the Filling
Finely chop the dark chocolate if you haven’t already and place it into a large glass bowl along with the cubed butter.
Then pour the cream into a small saucepan and gently bring to the boil. (Don’t continue to let it boil – turn the heat off as soon as it starts to boil.) Pour over the chocolate and leave to stand for 5 minutes.
Step 4: To Make the Filling
When the 5 minutes are up, give it a good stir until it’s smooth, melted, thick & shiny.
Step 5: To Make the Filling
Pour the ganache into the prepared base and smooth out with a spatula.
Step 6: To Decorate
Press in some marshmallows all the way along the tart and balance a few more on top of those to make a kind of marshmallow pyramid.
Take those 3 reserved Oreos from earlier and carefully cut them in half. (I only actually used 2 as I broke the 3rd – you can just eat that one like I did!) Press the halved Oreos into the tart. Finally scatter over the milk chocolate chips then chill in the fridge to set for at least an hour before slicing and serving.
Step 7: Take It Up a Level...
If you want to take it to the next level, toast the marshmallows using a blow torch. Then melt the 50g of dark chocolate in a bowl in the microwave in 15 second intervals, stirring well between each time until smooth. Pour the chocolate into a disposable piping bag, snip the end and drizzle all over the tart.
Store in the fridge and consume within 3-4 days.
Come on, how good does that look?!
I promise you that everyone will be begging you for this S’mores Tart recipe! What’s not to love? The crunchy Golden Oreo base? The mountains of chocolate? Or the sweet, toasted marshmallows? Yep, that’s what I thought!
For more awesome step by step recipes check out www.kitchenmason.com
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    4 Comments
    gahal235
    gahal235
    6 years ago
    is there anything you can substitute the golden Oreos for? maybe graham crackers ?
    KitchenMason
    KitchenMason
    Reply 6 years ago
    You could use any cookie to be honest. The only thing is if you didn't use a 'filled' cookie, the amount of butter you need may change. I'm not sure what to without actually trying it myself though :/
    These really look so good! I love the presentation and I'm sure they taste just as great!
    KitchenMason
    KitchenMason
    Reply 6 years ago
    Aww thank you!
