How to Make an Inverter Using ARDUINO
44,460
77
55
Introduction: How to Make an Inverter Using ARDUINO
Hi there, this project is all about designing an inverter from scratch, I am always fantasized by the projects which involves a software controlling an hardware. With this inverter, you can power up various electronic Appliances like TV, Fan etc.
Working : The aim of the inverter circuit is to convert 12VDC to 220VAC, Now to achieve this, we have to first convert 12VDC to 12VAC first followed by 12VAC to 220VAC
In short we can classify the designing of inverter circuit into three stages
1) Driver stage
2) Power stage
3) Transformer
Step 1: MAKING DRIVER STAGE
The tasks that are performed in driver stage are generation of modified sine wave, monitoring the battery voltage, handling the other housekeeping tasks such as short circuit protection etc. Here i have used an Arduino NANO to accomplish all these tasks.
Arduino is generating a modified sine waveform of 5V which is amplified to a level of 12V using L293D ic. Battery voltage is monitored every 20ms using timer interrupt.
Step 2: MAKING POWER STAGE
As the inverter output power is 600VA and it is 75% efficient so the input current at full load comes out to be 75Amp approx. (using ohm's law)
Now this current amplification task is performed by the power stage . In this stage two N-Mosfets are configured in push-pull topology to amplify the current.
Mosfet Chosen are IRF3205
Step 3: TRANSFORMER
Now this is very simple, the output waveform from the pushpull topology is fed into the transformer to generate the 220V.
Step 4: Designing Transformer
Designing transformer
Step 5: Schematics
This is the complete schematics drawn in Eagle software.
Step 6: Code
Here is the complete code of the Arduino.
Step 7: Complete Image of the Inverter
1 Person Made This Project!
  • Battery Powered Contest
  • Plywood Challenge
    Plywood Challenge
  • Plastic Contest
    Plastic Contest
55 Discussions
apollonios
apollonios
3 months ago
What about 2kW/24V?
monojithalder1
monojithalder1
1 year ago
My transformer has two wire in the primary coil and two wire in the secondary coil. Can i use this kind of transformer for making inverter? Thank you.
MacTech1
MacTech1
Reply 7 months ago
If ur transformer is having just two wires in the primary and secondary, I suggest u use an H-bridge topology and not a push-pull topology
gupxus
gupxus
Question 7 months ago on Step 7
Con la programacion de arduino de la pagina solo me da el pin 10 tensión. En el pin 9 no tiene tension o es decir falta la otra parte de la onda.
BriianR
BriianR
Question 1 year ago
Por que la salida A0 la conectan a tierra ??
9440885470
9440885470
1 year ago
Hello the output from L293d is 0.14v it does not drive the mosfet so output does not appear please give me solution
venkattalasala
venkattalasala
Question 1 year ago on Step 4
my arduino is not supporting timers..Can anyone tell me how to overcome this please
kaushalkhuntzz
kaushalkhuntzz
Question 1 year ago
Sir i ask that all grounds are common or mosfet ground are different from L293D IC ?? And also if all are common than its put on arduino ground??
mhmoudZ
mhmoudZ
1 year ago
Can you add a tranfirst irfp064 I also suffer from a very large temperature increase in transistors
ParthibA
ParthibA
3 years ago
great project
how did you design snubber circuit
ShailzaP
ShailzaP
Reply 3 years ago
As it is not a high frequency so i did not use snubber.
Tvixen
Tvixen
Reply 2 years ago
You must always use snupper circuit when working with sqare waves! Theres a lots of harmonic distortion.
SetiawanP
SetiawanP
2 years ago
Hello. How does the code modify if I'm not using battery?
DIY Hacks and How Tos
Cool. This will let you automatically turn the inverter on when you need it and turn it off when you don't
RashakaJ
RashakaJ
Reply 3 years ago
Any Idea how to intergrate crystal lcd to this project
Reply 3 years ago
There are a lot of ways that you can do it. But the easiest thing that you could do is just get an Arduino shield with an LCD display on it.
manish singhC
manish singhC
3 years ago
Sir could u tell the transformer rating to be used in this circuit & can i use 6-0-6 transformer
JagadeeshM6
JagadeeshM6
3 years ago
After including timer1header in the code it is again showing like this error code
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\Hackers\Documents\Arduino\inverter\inverter.ino:1:54: fatal error: Timer1.h: No such file or directory
#include "Timer1.h" // include Timer1.h
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
