Introduction: How to Make the Zippy Chain Bracelet on a Loom
This is a very easy very simple bracelet that has gorgeous results.
•loom
•hook
•c or s clip
•bands
Step 1: Placing Bands
You are going to start by placing your loom with the arrow facing up. Place a rubber band from the first one on the center to the first one on the left. repeat on the other side.Next place a rubber band from the center to the next one on the center. Do the same thing on the two other sides. place a rubber band diagonally from the middle to the left. Again repeat this step on the other side. Continue to repeat this process until you reach the end of the loom.Now flip your loom and add a capping band to that peg only.
Step 2: Hooking
Now reach under the capping band and take the band right under it. place it on the top of where it came from. ([Idk if that makes any sense 😅] As in image 1) Now do the same hing on the other side. Take the band in the middle and place it where it goes. and the once again do the sides. No take the bordering one and place it up like you would a single. Continue to repeat this process until you reach the end of the loomOne you reach the end, stick your hook into the end. Place a c or s clip into the other end of the bracelet
Step 3: Connecting/ Extentions
Take a band and pull it into the bracelet. Now pull the bands apart and place them on your fingers. Add one band at a time and place them over. Continue this process until you reach your desired length. ( like making a single on your fingers.) Now pull it carefully off of the loom. Connect the ends together and voilà.
DIY Summer Camp Contest
