How to Make Your Very Own Rainstick!
Intro: How to Make Your Very Own Rainstick!
Everyone has just about seen a rainstick, but their sound is hit and miss. You usually have to go through a few of them to find one that sounds good to your ears... but they dont always sound exactly how you want.
Well, this instructable will show you how to make your very own rainstick that is lightweight and uses common materials laying around the house. This build is extremely easy to tweak your rainstick however you want.
I have been making these ever since elementary school, they are extremely versatile and great for kids to make on their own.
Video of how the rainstick sounds is on the last page.
STEP 1: What You Need
You will need
1 screwdriver, either hand powered or electric (I used electric since its much MUCH easier and quicker)
1 fabric cardboard tube (see below)
duct tape
a bunch of screws
Something to make the sound (I used a little more than a half pound of lentils on this rainstick, but by all means, experiment with different materials. Pea gravel works extremely well.)\
Total Cost: around $3.00. (.25 for the tube and half of a $5 tub of screws)
Compare that to a $40 rainstick of the same size.
duct tape
a bunch of screws
STEP 2: Fabric Cardboard Tube
This is the rainstick, more or less. The longer your tube, the more sound you will generate. You can usually get a 4ft to 5ft tube at a thrift store for around .25 cents (thats where I got mine). You also want a thick walled one as well, to hold the screws in better and to put up with more abuse.
You can use just about anything, from plastic tubes, to PVC pipes, to even metal. I am using the cardboard because it is very easy to fix mistakes and to work with.
STEP 3: Making the Rainstick
This is pretty self-explanatory here. You take a screw, and screw it into the tube.
I try to keep the spacing between the screws the same at first, then I will add in more screws when I am nearly done to better tweak the sound.
STEP 4: Filling the Rainstick
I used lentils to fill the rainstick with, but I have built others with pea gravel, red beans, dried peas, even marbles. So make sure to mix and match what you use inside the rainstick to get the sound you want.
A good mix is lentils and something larger, like red or white beans. The lentils travel through the tube the fastest because of their small size, while the red beans follow slower, but continue and raise the sounds to a much larger and louder sound. Makes it more realistic in my opinion.
Play around with the different sizes and amounts until you get a sound you like.
STEP 5: Finishing the Rainstick
Once I get the sound how I like, through adding different materials and adding or taking out more screws, I usually cover the end of the rainstick with some duct tape.
If it doesnt look pretty enough for you, you could paint the whole thing, or cover it in tape, or whatever you want. I personally like the handmade look of the rainstick, and it shows people how easy it is to make one.
STEP 6: The Sound of the Rainstick
Here is a short video showing how the rainstick sounds.
I promise to get a better video up with better sound. Right now, all I had was my digital camera, and I should be getting a digital camcorder shortly.
29 Comments
DaveT2 9 years ago
For a continuous sound, you could build a square raintube, as another contributor to this site has done. Even better would be a circular one about the size of a steering wheel (no leaning curve!) that you could just turn continuously. You could modulate the sound by the speed at which you turned it.
phildavi 15 years ago
bwente 15 years ago
Flumpkins 15 years ago
mysterious ninja of fire 16 years ago
patricksanford 16 years ago
shooby 16 years ago
laminterious 16 years ago
http://en.wikipedia.org/wiki/Rainstick
Its about the same way normal ones are made, this though uses up the cardboard for a practical and musical use, instead of just letting it go to waste. If you had a tree that produced thorns, you could use the thorns instead of screws, but alas I dont.
static 16 years ago
To get a longer sound, you could put pieces of plastic between every few screws so they are sandwiched in so to speak as impulse94 suggested.
You can also attack a contact pic to it withe a foot pedal and an amp to get the sound to last longer.
The only other way I can think of would be to have the tube stationary and something makes the sound matrix/beans/whatever fall through the tube, collects what comes out, and dumps it back in continuously. Though that would be a big undertaking for something thats being used non-commercially. Though it would be a cool thing, kinda like those water fountains, but would be a rainstick fountain.
hippie_mama 16 years ago
static 16 years ago
Fitwit 16 years ago
BrianKT 16 years ago
foraneagle2 16 years ago
nc4tc 16 years ago
