How to Mod an Xbox 360 Wireless Headset to Increase Battery Life
Intro: How to Mod an Xbox 360 Wireless Headset to Increase Battery Life
In This Instructable I Will Show You How To Double The life Of Your Wireless Headsets Battery From
6 Hours To 12 Hours With This Very Simple Mod.
STEP 1: Materials
In Order To Do This You Need
1 Xbox 360 Wireless Headset
An Old Small MP3 Player (I Recommend A Audiophase KZIII MP3/VIDEO PLAYER)
A Soldering Iron With Rosin Core Solder
A Precision Screwdriver Set
And Some Safety Goggles
STEP 2: The Parts
First Start By Opening The MP3 Player By Removing The Four Screws In The Back After That Remove The Two Screws Inside To Access The Battery Than Grab Your Soldering Iron And Remove The Battery Carefully Because Its Taped To The Main Board And Can Damage The Battery If Not Removed Properly
STEP 3: Opening the Headset
Next You Need To Open The Headset Now To Do This You Must First Remove The Ear Loop Wear The Ear Loop Connects are The First Screws To Remove After That The Speaker Part Should Come Off Inside are Two more screws Then The Rest Of It Should Come Apart Then Remove The Battery From This the Same way You Removed The Battery From The MP3 Player
STEP 4: The Assembly
Swap The Battery's Out And Solder The Connections Together Put The Screws Back In And Its Done You Have Just Doubled The Battery Life Of Your Wireless Headset
15 Comments
flubbersaurus 10 years ago
earthcadet 12 years ago
spaten0 14 years ago
newtylerjh 13 years ago
DDjusD 14 years ago
quazzamuhaha 13 years ago
uberinsane 14 years ago
It would be nice if someone could find the battery by itself sold online. $10 for a battery would be a lot better than forking over another $60 for a new headset.
newtylerjh 14 years ago
DanAdamKOF 14 years ago
scott! 14 years ago
jbporter 14 years ago
