How to Photograph Birds in Flight the Easy Way
Intro: How to Photograph Birds in Flight the Easy Way
With a simple set-up, you can produce excellent photographs of birds in flight--from the comfort of your house! Birds are attractive targets for wildlife photographers. They are aesthetically pleasing, ubiquitous, and charismatic. But once one has mastered the "bird on a stick" photo, a photographer may feel challenged to produce more interesting photos. Bird in flight (BIF) photos are dramatic, but much harder to get. Some degree of chance is usually required, and a long time in the field. The method demonstrated here is relatively simple and allows one to take BIF images in the dead of winter, when birds are most drawn to feeders. Meanwhile, the photographer is warm and cozy.
STEP 1: The Set-up
This project involves carefully planning of the arrangement of objects in space. First, you need a bird feeder. You may already have one, but make sure it is placed in an optimal location, typically near a large window of your dwelling. Place a perch 8 to 10 feet away from the feeder, opposite the direction of the house and somewhat off to the side. This plan takes advantage of the fact that birds like to land near a feeder and check it out before flying to it and consuming the seed. Photograph the bird when it flies from the perch to the feeder.
The type of feeder doesn't matter much. I use only sunflower seed in my feeder, as most birds really don't care for the other seeds in mixed bird feed. I also use a suet feeder, which is a great way to attract woodpeckers.
It's best to use a natural stick, such as one that's fallen from a tree. You can jam it into the ground or use a support like an umbrella stand to hold it up. The top of it should be about the same height as the bird feeder. By using a natural stick rather than a human-made object, you can get natural-looking photos of a perching bird if you want them. You may need to move it around to find the spot that the birds prefer. It's also better if there are not competing objects that can be used as perches nearby. Finally, try to use a location that will result in photographs with a pleasing background.
Inside the house, place your camera on a tripod as close to the window as is practical. Ideally, the sun should be behind the camera, which may affect which window you choose to use for this project. If the sun is directly behind the bird, you will get only silhouettes of birds, which are not very gratifying. The window should be thoroughly cleaned inside and out. Make sure there are no reflections in the area of the window through which you are shooting. If the end of the lens is very close to the window, there should not be any reflections in the images. Adjust room lighting if necessary. Even double-paned windows should have little noticeable effect on image quality.
STEP 2: The Photography
Equipment
The camera must have some degree of manual controls. Almost any DSLR will do, and many superzoom point-and-shoot cameras will also work (my equipment is detailed in a photo above). The length of the lens required depends on how far the feeder is from the window. If the feeder is far away, a longer, presumably more expensive lens will be needed. The tripod doesn't need to be fancy, as long as it holds the camera firmly.
The camera should have Av mode, or Aperture Priority. Set the camera on this mode and adjust the aperture to F/8, or about two stops above the lowest F-stop. This setting will provide adequate depth of field and minimal aberrations. Set ISO to the lowest natural level of your camera. For example, my Canon 7D can be set as low as ISO 100, but its true minimum is 160. You should shoot on a sunny day, otherwise higher ISO will be needed and the images will become more grainy. White balance should be set on automatic or full sun. These settings work in your favor in that the camera will automatically choose the highest shutter speed that can produce a properly exposed image, resulting in freezing the motion of the bird's wings. If you have the equipment and know-how, you could set up a remote flash and probably get more consistent results, but that's beyond the scope of this Instructable.
Place an object halfway between the perch and the feeder and prefocus your camera on it using manual focus. Leave the camera on manual focus and try not to bump it. Set the lens at a zoom level that is reasonably wide. If you zoom it too tightly, you'll cut off bits of the birds in every frame. It's better to have the entire bird in the frame and crop it later.
Shooting
If you have one, connect a remote shutter to the camera to minimize camera shake. Set your camera on burst mode if available, and wait for a bird to land on the perch. Now place your finger on the shutter button (or remote button). As soon as the bird moves to fly, hold down the button to take a rapid series of photos (a burst). Let off the button when the bird reaches the feeder. At some point during the bird's flight, it should be in focus and in frame for at least one image. Delete the rest. It will likely require some experimentation and adjustment to get the best results. Some photographers prefer not to use burst mode, instead using their own natural skill and timing to capture a single ideal image of such a natural moment. This strategy takes considerable skill. Birds are fast!
Post-processing
It almost goes without saying that you should crop the photo and make some global lighting adjustments to make the best image you can. You may capture birds in some interesting positions. I provide a couple of examples here.
13 Comments
Vaibhav216 2 years ago
chienline 2 years ago
Mostly can't control the background. Then I lost focus when it departed. Then I try playing with bees which hover a lot while approaching the flowers :D
Patient and time.
Love it. Great tip.
shalnachywyt 2 years ago
Show Me Joe 2 years ago
RobertK255 2 years ago
That feeder was not even up a day when something, probably a raccoon, jumped up, grabbed it and dragged it down to the ground, and all the seeds spilled out. I went and re-attached it to another branch with a stronger knot. Nevertheless...
I'm completely convinced that after humans kill themselves off with climate change, wars, virus and other inimical-to-human-life incidents, that raccoons, who have opposable thumbs, will be taking over the Earth. Well, them and cats, dogs and chickens. :)
charlessenf-gm 2 years ago
Did you try a video or two?
I may try this setup using my trail cameras as I don't have a camera like yours.
John DuCrest 2 years ago
Raphango 2 years ago
jessyratfink 2 years ago
