How to Program Arduino Bluetooth Serial Communication in Visual Basic Express 2010
Intro: How to Program Arduino Bluetooth Serial Communication in Visual Basic Express 2010
There are various Android Program/Software to control your arduino bluetooth robot with your android. But you can not find one to use with your windows PC. So I program a LITTLE one In Visual Basic Express 2010. Hope it might be helpful as a resource to beginners in Visual Basic GUI Programming. And if you enjoy it please leave a feedback. I do my best in this first INSTRUCTABLES.
Sorry for spelling & Grammar mistake in advance.
STEP 1: How To
Start Visual Basic Express 2010.Open a new window with a blank form. Add two Group box from Containers Toolbox menu. Change text of this two box to Connection Settings and Serial monitor. Then add a label , combo box and a button to the 1st group box and change the text and name as follow-
label: text to "COMM PORT" combo box: name to "lstPorts" button: name to "Button1"
In 2nd Group box add a list box and change the name to "lstConsole" and a button and change the name to "Button2" and text to "Exit"
STEP 2: Insert Control Button
Now add your five button to control the movement and set the name and text to:
Button3 to "Forward/w"
Button4 to "Backward/s"
Button5 to "Left/a"
Button6 to "Right/d"
Button7 to "Stop/c"
Button8 to "Bluetooth Test"
STEP 3: Programming
Now we program every components of the Form. First Form load code.To do so double click in any where in the form and change the code to
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load GetSerialPortNames() End Sub
Then add some additional code above the Form1_Load code to get your comm port and some function to work with your software
Imports System.IO Imports System.IO.Ports Imports System.Threading
Public Class Form1 Dim buffer As String Delegate Sub myMethodDelegate(ByVal [text] As String) Dim bD1 As New myMethodDelegate(AddressOf process) Dim WithEvents SerialPort As New IO.Ports.SerialPort
Private Sub Form1_Disposed(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Disposed If SerialPort.IsOpen() Then SerialPort.Close() End If End Sub
And below the code of Form1_Load
Sub GetSerialPortNames()
For Each sp As String In My.Computer.Ports.SerialPortNames lstPorts.Items.Add(sp) Next End Sub
Sub SendSerialData(ByVal Port As String, ByVal data As String) If (SerialPort.IsOpen) Then SerialPort.Write(data) Else MsgBox("Not connected to Port.") End If End Sub
Sub process(ByVal myString As String)
buffer = buffer + myString Dim str As String str = buffer If InStr(str, "|") Then Dim words As String() = str.Split(New Char() {"|"}) buffer = "" Dim word As String For Each word In words If (word.Length > 0) Then lstConsole.Items.Add(word) End If Next End If End Sub
Private Sub SerialPort_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialPort.DataReceived Dim str As String = SerialPort.ReadExisting() Invoke(bD1, str) End Sub
STEP 4: Intitialize Connect
To initialize the button "Connect" replace the button code with
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
If lstPorts.SelectedIndex <> -1 Then Try If SerialPort.IsOpen Then SerialPort.Close() Button1.Text = "Connect" Else SerialPort.PortName = lstPorts.SelectedItem.ToString SerialPort.BaudRate = 9600 SerialPort.DataBits = 8 SerialPort.Parity = Parity.None SerialPort.StopBits = StopBits.One SerialPort.Handshake = Handshake.None SerialPort.Encoding = System.Text.Encoding.Default SerialPort.Open() Button1.Text = "Disconnect" End If Catch ex As Exception MsgBox(ex.Message) End Try Else MsgBox("Please choose a serial port", vbInformation, "Serial Port") End If End Sub
Click the Button "Bluetooth Test" and replace the code .This button click will recive a messege in consol as "OK" to confirm that bluetooth is connected with the device. Else "ERROR" to say something wrong in connection.
Private Sub Button8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button8.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "AT") End If End Sub
STEP 5: Code for Control Keys
Now replace the code of each button as follow to control the movements
Forward:
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "w") End If End Sub
Backward:
Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "s") End If End Sub
Left:
Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "a") End If End Sub
Right:
Private Sub Button6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button6.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "d") End If End Sub
Stop:
Private Sub Button7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button7.Click
If (lstPorts.SelectedIndex <> -1) Then SendSerialData(lstPorts.SelectedItem.ToString, "c") End If End Sub
To close the software we must program the quit button as follow
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Application.Exit() If SerialPort.IsOpen Then SerialPort.Close() End If End Sub
STEP 6: Finalize the Build
For Modification and design Purpose you can now change the Form1 Title text to your choice name as I change it to "Arduino Bluetooth Communication".
Now you have done. Save the projects with any name of your choice. Then from Debug menu click Build. When successfully done you got your own "Arduino Bluetooth Communication Software".
N.B: I assign some key to the buttons as follow-
Forward-> "w"
Backward->"s"
Left->"a"
Right->"d"
Stop->"c"
means when you click the any button it execute the assigned key to arduino so you need to program your own arduino sketch with this key to control. You can also change the baud rate,parity,data bit etc when initialize the code for Button1
The source code is here for reference:
9 Comments
amirmosh 4 years ago
I use Excel's VBA for my macro coding, so VB is a bit new to me...
I encountered your article while looking for help trying to learning a bit on BT connection from my laptop to another BT device (my water cooling machine, for example)
I would like to receive some info. from it (water Temp.,for example)
(The machine has a BT function...)
I started reviewing your code & copied it to "VB express" & while starting to "play" with it,
I saw that the "lstPorts" is emplty.
Can you explain what should I do ?
Thanks
EagleFive 4 years ago
// Refer to your own Device Manufacture
// Same here
"lstPorts" is empty normally occurs when COM port is busy or the PC's bluetooth connection turned off or bluetooth is blocked by outgoing firewall policy.
Check all the steps. Hope you will find the solution. Have a nice day.
Thank you very much for replying...
My bt is on & my computer is paired with the water cooling machine.
I dont know the machine bt module spec.
Anyway even if I did know, while running the code step by step,I can see that in the
"Getserialnames" procedure, the port names
Are empty.
Can You direct me to find why?
Thanks
Are empty.
Thanks
StenB 6 years ago
n Mon, Mar 12, 2018 at 5:30 AM, Sten Björsell <sten@ship.ie> wrote:
The USB dongle I got is Backward compatible with Bluetooth v3.0, 2.0, 1.2 and 1.1 devices
I have ordered a new dongle compatible with Bluetooth ver 2.1 now.
Will check this tomorrow again!
Note that the communication works fine on my android phone using a Hyperterminal software.
I even requested and received 4 digit analog to digital value to the phone, perfect.
With PC interface I can add checksums for further integrity.
Many thanks for your reply.
Sten
StenB 6 years ago
When I test with button 1 I get "access denied".
When I add the Bluetooth dongle I get 2 new com ports on the laptop. Com7, com8
Both labelled "incoming"
When I pair with the Bluetooth device Another comport is added. Com9, labelled "outgoing"
When I test with button 1 I get "access denied", for any of the 3 ports.
I got the same result with other software in the form of "exception, access...", which works on direct serial port via USB converter.
I can communicate with the Bluetooth device connected to an ATMEGA168PA from my android phone perfect, both ways. What is wrong? The dongle is a RNBT-C06F from Cambridge Silicon Radio, BLuetooth 4.0
The Bluetooth on the Atmega is RN42-I/RM
All help appreciated!
EagleFive 6 years ago
I think you have problem with your PC's bluetooth driver. So you can try to uninstall the bluetooth driver from your PC and Also re insert the dongle then installing the compatible driver for the dongle and Give it a try. Also check your program code for ATMEGA168PA MCU because you are using "Microchip RN 42 Series Class 2 Bluetooth® Module with On-Chip Antenna". Thank You.
seamster 8 years ago
Nicely done. Thanks for sharing this!
EagleFive 8 years ago
You welcome.
