Introduction: How to Re-Cover Chairs
An easy way to fix up old or used furniture. Why didn't we do this earlier?
Step 1: Before
Here's an old chair with a ratty seat cover.
We got it from Craig's List about three years ago. The seats had been re-covered in a neat red silk that looked good but didn't wear well. After months of ignoring the shredded red silk, we finally yanked it off to discover the original black fabric, which also looks pretty bad.
Since we were planning to have 40 people over for Thanksgiving the next day, it was the perfect time to start a new project. Right.
Step 2: Find Your Fabric
We headed off to the local fabric store to find some nice, thick upholstery fabric. This will wear better than that thin silk, and hopefully stand up to years of daily abuse at our kitchen table. I chose some nice swirly blue stuff that should look good with the dark brown wood of the chairs.
Thrift stores are also a great source for material- pick up an old jacket, skirt, tablecloth, or anything else with a nice thick fabric and neat design. Just make sure it can stand up to the level of use you'll be giving it.
You don't need much fabric- just the size of the seat plus a couple of inches around each edge of the seat. Remember to measure your seats before running off to the fabric store, or else you'll have lots of extra fabric, or worse, not quite enough. (I'm planning to make cloth napkins from my leftovers. Eventually.)
Remove the chair seat and place it upside-down against the back of the fabric. (Remember the good stuff should be facing up when you're done.) Make sure it's properly aligned with your fabric's pattern, especially if there are stripes involved. Trim around the edge to leave enough fabric to fold over on all sides. Depending on the thickness of your cushion, this could be 2-5 inches.
Step 3: STAPLE!
This is the fun part- an excuse to use a staple gun. Ours is a sweet electric version that can punch through most anything. In any case, be careful- don't staple your fingers, your eyes, your leg, or anything else but the fabric and the seat back.
Start with the flat front side, and staple from the center out towards the edges. You want to make sure the fabric is smooth and tight, without bunches between your staples. This is much like wrapping a present- if you can do that, you can re-cover a chair.
Now spin the seat, and tug the back of the fabric into position. Pull firmly against the front row of staples to be sure you've gotten rid of any wrinkles or bunches. Again, start stapling at the center and spread outwards.
When the seat back starts to curve, take folds/tucks in your fabric. The goal is to have all the bunching UNDER the seat, not on top. Try a few different things, and see how it works. Remember, you can always pull the staples out and try again until you get it right.
Staple the sides, again tugging firmly to make sure the fabric is tight over the top of the seat.
Do the corners last. I found it best to take a fold on each side of the corner, then make a pleat along the diagonal- look at the pictures for inspiration, then do what works best for you. Again, yank staples and re-do anything you don't like.
Things to think about:
1) How many staples to use? My staples were kind of small, and I love stapling, so I used more than absolutely necessary. Scale as appropriate for your fabric, staple size, and entertainment, but make sure you use enough to share the strain across your fabric.
2) Where do the screws go? If you have to screw your seat back on, take care not to block the screw holes with lots of fabric or staples. You can go through one layer of fabric easily, but staples are a problem.
3) Is it tidy? Be sure to hammer down any staples that aren't flush, and trim any extraneous blobs of fabric.
Step 4: Stain Protect
We sprayed the new seat covers down with Scotch Guard. This little can held enough to do only six seats; luckily we only needed four.
Set up some milk crates or other support structure, and spray the seats according to package directions. Be sure to do this OUTSIDE, as the vapors are pretty foul and probably carcinogenic.
Let them dry overnight in a protected but well-ventilated area. If you can put them in a porch or garage this will protect you from the vapors while also protecting your shiny new seats from dangerously well-fed birds.
Step 5: Reassemble and Use
When the seats are dry, reassemble your chairs.
These required a screwdriver, which made Eric fussy- I think he knocked his knuckles against the rail when installing the center-back screw.
Use and enjoy your newly-refreshed seating, and wonder why you didn't do this earlier. Start checking out the rest of your furniture, and wonder whether recovering a couch is really that much harder.
20 Comments
12 years ago on Introduction
OK!!! )
13 years ago on Introduction
here is my chair :)
Reply 12 years ago on Introduction
Oh wow, you're right - it's identical fabric! Your chair has some additional curlicues, though. Nice job!
this is beautiful and pretty eerie, i recovered a chair about a year ago and stained an almost identical chair that stain color, and the fabric is the same! can i take the chair off your hands so mine has a twin? nice work :)
I just wanna say: Yeah... reupholstering a couch is a LOT harder (just trace the outline on the bottom, the back, and about 3 or four times on each side and imagine that under your finger there are anywhere from 1 to four layers of staples, not to mention the upholstering process)
Those are lovely. I really like that fabric.Nothing like the night before to create something pretty !
14 years ago on Step 5
Lovely job! Thanks for posting this.
14 years ago on Introduction
Hey those are nice chairs.
I use a hot glue gun which IMHO works better than staples. It actually fuses the fabric together w/o stress points and I can reach places inaccessable to a stapler. There is also the advantage of no sharp things to get poked w/ either now or later. Just don't get burned on the gun!
Wow! I bet those match the purple turkey!
Reply 14 years ago on Introduction
Well, they match the blue turkey, but ours were unfortunately pre-brined, so I didn't get the chance to color them.
Waitwaitwait... ours -- as in more than one!? You really are crazy! I knew it all along!
Then again... 40+ people... gahh! still shocking!
By the way, nice robot swag!
Why do you have to coat them with the scotch guard? Is it just to make it more stain-resistant?
Last year we had 2x22lbs turkey; this year we had 2x15lbs, and probably should have done more. The scotch guard is to make them stain resistant at all. ;)
Dig that funky blue fabric. Curiously enough, I re-covered three chairs with some green upholstery fabric, that I'm sure is the same pattern as yours. The curious part being that I found my fabric under a layer of worn-out fabric, on a ratty old couch, that I was preparing for retirement. The couch had to be about 30 years old at the time. Good to know that the pattern is still available. By the way, you should get some plywood and foam, and upholster your milk crates as well...
THANK YOU!! I've been too lazy to attempt this before.
We waited months due entirely to laziness. It's far easier than I had thought.
What changed? Basically, my mom came to visit, called us wimps, and removed the damaged silk covers- then we had to finish them.
hahaha. Sometimes an..erm..gentle push is needed!
sctoh gaurd fumse r col
just kidding
smart! cool :-)
