How to Re-Tip a Knife Using Dremel
59,145
177
15
Introduction: How to Re-Tip a Knife Using Dremel
About: dreaming it and doing it!
So I've had an old and lonely chef's knife hanging out in my knife kit for a while now.  I retired it and bought a new one shortly after a coworker used it to pry open a stuck robot-coupe and cracked off the tip off.  People are no longer allowed to use my knives to say the least...hard lesson learned indeed!  Well, I was looking at this knife the other day and thinking about how perfectly usable it is, except for the fact that it has no tip...an essential item for speed and/or precision knife cuts. Soooo I thought...why not?  No job Dremel can't handle!  And so it was...pulled out of retirement and fully repaired, my trusty work companion and arm extension is back in action!  In this instructable I'll show you how to save a few bucks by repairing your own knives.
Step 1: Gather Materials
To put a new tip on your knife you'll need the following:
  1. Broken knife
  2. Marking device such as a pen or marker
  3. Dremel
  4. Dremel Attachments (metal cutting blade, grinding bit, sanding bit, wire polishing brush, synthetic polishing brush, and felt polishing tip with polishing compound applied)
  5. A clamp for supporting the knife
  6. A sharpening stone or other sharpening device
  7. A honing steal
Step 2: Mark the New Tip
Using a sharpie or other marking device, draw on a new tip.  Shade in the section you want to remove.  If you want to see the end result put a cloth of the same color as the pen and then hold the knife up to it (e.g. I used a black sharpie so I held the knife up to a black cloth), you will be able to see the shape of your new knife.  I wanted to preserve the length of this knife and also avoid having to put a new cutting edge on it, so I opted to shave just a little off the top.
***Note:  Using this method will slightly change the shape of your knife.  To preserve the shape, take some off the top and bottom, then put a new cutting edge on it yourself or have a professional do it for you.
Step 3: Clamp the Knife to a Work Surface
Clamp the knife firmly onto your work surface.  I do not reccomend holding the knife in your hand while trying to do this for two reasons 1.  It is extremely dangerous! 2. You may end up with a jagged or uneven edge.
Step 4: Removing the Excess
Use a dremel with a metal cutting blade attached to it to cut off the dark shaded area.  Run the dremel full speed, however slow and steady motions with very light pressure will produce a nice rounded cut.
Step 5: Grind, Sand, and Polish
The hard part is over.  Now use the dremel with following attachments (in numerical order) to clean up the cut.
1.  Grinding bit
2.  Sanding drum
3.  Wire polishing brush
4. Synthetic polishing brush
5. Felt polishing tip with a small amount of polishing compound applied to it
***Note: I ran my dremel 3000 at a speed of 4 when doing this and ended up with an identical shine.
Step 6: Sharpen the Cutting Edge
Now run your blade along a double sided sharpening stone a few times to bring back the tip's edge.  I used an aluminum oxide, two sided sharpening stone followed by a diamond impregnated honing steal to get it nice and sharp.
Step 7: BAM! Like New!
Aaaaaaaand Bam! Just like that...a knife brought out of retirement, with a whole new look too.
Be the First to Share
    • Audio Challenge
      Audio Challenge
    • Halloween Contest
      Halloween Contest
    • Robots Contest
      Robots Contest
    15 Comments
    Casull
    Casull
    11 months ago
    You can do the same on the flat part of a belt sander, clamped on its back to the table :
    - There is less risk of grinding error (dremel rolling to the edge side)
    - Work from the back, toward the point (to prevent it from snagging in the band)
    - Your tool is fixed, so you can cool the blade in conveniently placed water.
    - You can hold your finger closer and safer to the zone you grind to feel any rising temperature.
    - You can refine the grit and pressure until your desired finish.
    Eezoxnuffsaid
    Eezoxnuffsaid
    5 years ago
    I have 3 Dremel tools, I love them, I also have a WORKSHARP KEN ONION EDITION KNIFE AND TOOL SHARPENER, which I love way more. It's a small belt sander, grinding tool that doesn't produce near the heat of a Dremel. We had an old saying when I was coming along gun smithing "Another fool with a Dremel Tool" any knife I work on that gets warm, I dip in cold water well before temper is affected, dry off start again, cold. Great vid!!
    JFabor
    JFabor
    Reply 5 years ago
    Thank you, and good idea with the water. I love dremel and all their products. There's nothing that cant be done using one of them!
    tkalko
    tkalko
    8 years ago
    As some have properly noticed, the excessive heat can easily lead to damaging the blade. The damage from loss of blade heat treatment is not something to worry about in a 10$ kitchen knife, but for any quality knife dremel should be avoided if possible. For smaller tip repairs just prolonged sharpening with a coarse sharpening stone (or a quality sanding paper on a mouse pad) will do - but it will take slightly more time than the dremel butchering (depending on the blade steel and sharpening tools beinv used)
    jarikcbol
    jarikcbol
    I was about to point this out myself, heat from abrasive cut off tools can really be bad for good knives. I've done several knives simply by marking it out, and slowly grinding it down on a cheep coarse sharpening stone while listening to an audio book or listening to a show on TV (pay more attention to the knife than the TV tough, stay safe!) Takes longer, but you don't risk messing with the temper of the metal as much.
    gwiener1
    gwiener1
    8 years ago
    I have the same knife set from my years at the CIA. :) thanks
    JFabor
    JFabor
    I share your Alma matter. Class of april 2009. :) this was my school issued knife.
    gcanders
    gcanders
    Great! I have to do this with a Shun knife I invested over $300.00 in. Thought the missing tip is very small, in my case, the tip that is left is slightly bent. Any idea how to unbend it without breaking it further? I was counting on the heat from the grinding to aid me in unbending it, but maybe I should keep it cool during the grinding and find another method to straighten it. The tip that is missing is 1/32" but it is noticeable when the knife is shown with my other knives. They are hanging on a magnetic knife holder on the wall. One day, I grabbed it, but dropped it on the counter and bamm, the tip broke and bent the knife at the end.
    JFabor
    JFabor
    I also own a couple shuns...its probably not wise to retip a shun utilizing this method. i know shuns come with a lifetime warranty. U should be able to send it in to the company, and they will either repair it or send u a new one. Visit the official shun link for more details.
    knottyarts
    knottyarts
    8 years ago
    The heat generated by cutting will possibly ruin the temper of the tip. It depends on the knife, how you cut it, if you use an oil or some other cutting fluid, and dozens of other factors. The two big things I would add here are 1) use some sort of oil or cutting fluid when reshaping the tip. Less friction equals less heat. And 2) work in 1-2sec on 4-8sec off bursts. You will accumulate heat much faster than you lose it. If the steel becomes colored in any way (blue, brown, etc.) you burned it.
    Personally I just rebuild the edge to create a new tip, but most people don't have the patients for the hours of hand work that requires.
    vumbaka
    vumbaka
    I think the heath produced by the friction of the power tool could damage the temper of the blade, couldn't it?
    tkjtkj
    tkjtkj
    Re: vumbaka ... re: heat causing loss of temper
    My guess is that as a dremel is use intermittently ( ie, ? 2 secs cutting,, few secs off the work ..etc) that risk is very low .. Further, i really doubt most knives are tempered at all .. otherwise, they'd be a bit** to sharpen ..
    The volume of knife metal, too will suck heat quickly ..
    But you're good to raise such important considerations no doubt applicable to many heat-producing tool use ... but not in this case ..
    tkjtkj
    tkjtkj
    Yes .. good job ... Dremel's are handy!
    BUT:
    Do add to your 'Required Items' list: Safety Glasses or full face shield!!!
    Phil B
    Phil B
    Congratulations! It gives you a good feeling to restore something like this knife to a useful condition. Sometimes I appreciate the restored item even more because I feel like I have made it mine in a way it was not before.
    I did something like this on a smaller stainless steel general purpose knife owned by my mother-in-law. Someone had used its tip to pry and the tip broke. I ground a little on both the cutting edge and the back of the knife for aesthetics. All I had available was a standard electric grinder. I ground slowly and kept it cool with water. Although it was not a quality knife, the knife was more useful with the point restored.
    JFabor
    JFabor
    Phil B, Thanks! I agree with you, after restoring this knife I experienced a whole new sense of connection to it. I appreciated it before, as it was the knife I learned how to cut with, and I've prepared many delicious foods using it, but now the experience is a little more intimate. Such a fulfilling task!
    Good job with your mother-in-laws knife! I've seen so many knifes over the years be disrespected and used for all the wrong tasks, then as a result of misuse they end up as pieces of junk people cast aside to be forgotten forever. Kudos to you for recognizing the potential of an otherwise forgotten item!
