How to Read Manga on Your Kindle
Intro: How to Read Manga on Your Kindle
(This can also be done with comics)
What you need:
1) a program for kindle by Kovid Goyal
• Calibre (it's free and you can download it here)
2) Manga files ( preferably in JPEG, PNG, or JPG)
• it doesn't matter whether they're compressed or not
3) WinRAR, 7zip, or any other tool similar to these
4) a kindle (of course) with its usb cable
STEP 1: Making the Files Compatible for Calibre
A regular folder full of picture is not considered to be a file that can be converted.
1) If you have a .RAR file, Extract the files. (If it is not compressed, skip to the next step)
• Right click, select your decompresser ( I use 7zip), then extract here
2) Open up your folder that is NOT compressed and highlight all the contents or just press Ctrl A
(should only be picture files)
3) Right click the highlighted files and select "send to", and then "Compressed (zipped) folder"
Now Calibre will consider it to be a readable file!
STEP 2: Converting and Importing Your Manga
Now your files can be converted and imported.
1) open up Calibre and on the top left corner, select add books
2) select the compressed (zipped) folder(s) you have made and wait for them to upload
3) highlight the you manga files and right-click them
• select "convert books" and then "convert individually" (or "bulk convert" if you're doing more than one)
•then select "MOBI output" on the left side and then "OK"
(converting them will take a while)
4) Now plug in your Kindle and right click the files you want to import to your kindle
• select "send to device" and then "send to main memory"
5) Now you're done!!! eject your kindle and enjoy reading your manga anywhere!
UPDATE: For pages that are scanned two pages at a time, you can split them by choosing the "right to left"
option in the "comic input" section during conversion.
If you have any questions leave them in the comments below and i'll try my hardest to answer them A.S.A.P.
26 Comments
DinosaurS1 9 years ago
Idk if anyone's posted this yet (tldr and all that) but A.F.5 Rename is a good tool to use when renaming manga.
KatTayle 11 years ago
Shizuzu 10 years ago
I had this same problem, and after some tinkering around at 2 AM I found a good solution.
I'm assuming the manga is similar to this situation:
There is a folder to each Volume and inside of each volume there are more folders to each chapter/ act.
To make each chapter/ act into one uniform folder that calibre can detect, Go to the folder with all the pictures, assuming those pictures are all for Chapter 1, press Ctrl+A and then right click on the first picture and click on rename. Then Type in V1C1 (Volume 1 Chapter 1) then press enter, Your files should be named V1C1 (1), V1C1 (2) and so on. Then move these files to the original Volume folder, then continue with this process with the next chapters (Chapter two would be V1C2), moving them to the original volume folder. Then highlighting all of your renamed files, put all of them into one compressed file (Probably naming it Volume 1). This way there are no pesky folders in the way, and the pages stay in the right order.
I really hope this was what you were looking for!
RIU 11 years ago
JavaT1 7 years ago
This was so useful - and it works for Kindle Fires, which is great. I wanted to read Corpse Party but couldn't afford all the books. This is great though.
MichiL 8 years ago
Or if you have any newer kindle, you can just zip the images and put them to your books in the documents directory.
EbooksP 8 years ago
really good Post :)
petinexus 8 years ago
Thanks man :)
KevinA19 8 years ago
NamH2 8 years ago
Download manga for Kindle:
http://mangaforyourkindle.blogspot.com/
NamH2 9 years ago
Manga for kinle http://mangaforyourkindle.blogspot.com/2015/05/choose-your-manga.html
NamH2 9 years ago
NamH2 9 years ago
deoxxys 9 years ago
Can I use PDF files?
martin.benjamin.522 9 years ago
Thank you for the great info! Finally I can get to read some manga on my old unused Kindle! Yey!
kawaii_mom 10 years ago
I WOULD HAVE NEVER BEEN ABLE TO DO THIS WITHOUT YOU!! and it was the whole reason I got a Kindle... but I'm picky so i have to bring something up. I noticed that the cover fills the screen from top to bottom yet every page in the book following has a small margin at the bottom and it squishes the rest of the page. is there any way to get rid of that margin? I was thinking it had something to do with the file size but the cover is just fine and dandy. THANKS!
Caskett 10 years ago
Despite wasting literally hours, I can not get this method to work. First I was getting errors because apparently sub-folders aren't allowed. After I found this out, it doesn't matter how i name the files it REFUSES to put them in the right order. I tried CH01 (1...) for all chapter 1 files, then CH02 (1...) for chapter 2, etc. When that wouldn't work, I tried naming them all the same and let windows auto number them. However, despite them being in the right order on Windows, they still have no real pattern on the device. Unless I create 81 seperate e-books or manually name each picture as 000001, 000002; then I can't get this method to work. Probably spent more time working on getting this to work then it I would have spent reading them...
Buky92 10 years ago
shaowei 10 years ago
RIU 10 years ago
