Introduction: How to Run an Auto Steer in a 2019 John Deer
The simple way to run John Deer auto steer
Step 1: First Step Is to Start the Tractor Up
The first step to do is
start tractor and let it warm up for fifteen to twenty minutes. After that press the ok button on the top corner of the screen, then go to auto track and use the arrows on the top right corner on the screen until the operator get the guidance screen on the left top corner.
Step 2: Step 2 Should Go to the A&B Line
At the bottom left corner there is a tab that says guidance the operator
should press that button twice. The next step is to setup the tracing which the operator should scroll down until they see the new tracking button click that, then press straight tacking tab on the left side you will want to press the A + B Method. Begin at the start of the field and progress your way through the field with using auto steer.
Step 3: Step 3 Start a New Tracking
At turns the operator have to manually use the steering wheel to get to
the next rows you would like field cultivate. When approaching the end of the field you want to switch to the B method in the top left corner and it will create of mapping of the field for the operator to what all has been covered.
Step 4: Step 4 the End Page
The next rows you would like field cultivate. When approaching the end of the field you want to switch to the B method in the top left corner and it will create of mapping of the field for the operator to what all has been covered.
