How to Stream Live Videos Through Raspberry Pi Using a Webcam
Intro: How to Stream Live Videos Through Raspberry Pi Using a Webcam
I'm Gonna Show you How to Stream Live Videos through Raspberry!
Also visit Pi My Life Up! : pimylifeup.com/raspberry-pi-webcam-server/
Blog : https://surdeepdevanathan.blogspot.in/2017/09/how-...
Watch the Video to avoid Confusion!
STEP 1: Get Your Things Ready!
You need :
- Raspberry Pi.
- USB Webcam.
- PC.
- USB Cable.
- Wi-Fi network.
STEP 2: Connecting Webcam :
Initiation :
- Connect the USB Webcam to the Pi.
- Power up your Pi.
- Connect it to the Wi-Fi network.
- Make sure your PC/Laptop are connected to the same network.
Configuration :
- Now using LX - Terminal Login to your Pi.
- Follow these steps to Install the Camera Packages: (ENTER THESE COMMANDS)
- sudo apt-get update
- sudo apt-get upgrade
- RESETTING : sudo apt-get remove libavcodec-extra-56 libavformat56 libavresample2 libavutil54
wget https://github.com/ccrisan/motioneye/wiki/precomp...
sudo dpkg -i ffmpeg_3.1.1-1_armhf.debsudo apt-get install curl libssl-dev libcurl4-openssl-dev libjpeg-dev libx264-142 libavcodec56 libavformat56 libmysqlclient18 libswscale3 libpq5
sudo dpkg -i pi_jessie_motion_4.0.1-1_armhf.deb
sudo apt-get install libmariadbclient18 libpq5 libavcodec57 libavformat57 libavutil55 libswscale4
sudo nano /etc/motion/motion.conf (FOLLOW THESE STEPS)
■ daemon on
■ stream_localhost off
■ Note: Change the following two lines from on to off if you’re having issues with the stream freezing whenever motion occurs.
■ output_pictures off
■ ffmpeg_output_movies off
■ Optional (Don’t include the text in brackets)
■ stream_maxrate 100 (This will allow for real-time streaming but requires more bandwidth & resources)
■ framerate 100 (This will allow for 100 frames to be captured per second allowing for smoother video)
■ width 640 (This changes the width of the image displayed)
■ height 480 (This changes the height of the image displayed)
sudo nano /etc/default/motion
start_motion_daemon=yes
Once you’re done simply save and exit by pressing ctrl+x then y.
sudo service motion start (TO START)
sudo service motion stop (IF YOU WANT TO STOP)
sudo service motion restart (RESTART IF IT DOESN'T WORK)
STEP 3: Output :
- Now Open Google Chrome or any Web Browser.
- Type the Raspberry pi's IP address and the Port number
- You should get your Output!
- If it still doesn't work Watch this Video :
or email : voxton95@gmail.com
We're finally done I hope your's works fine!
Thank You!
