How to Strip Wire (Without a Wire Stripper)
Intro: How to Strip Wire (Without a Wire Stripper)
This is a method of stripping wire that one of my friends showed me. I noticed that I use wire for a lot of projects and don't have a wire stripper. This way is useful if you don't have a wire stripper and you're either broke or too lazy to get one. It may seem like it takes a while to do, but once you get used to it it barely takes any time at all. This method is similar to the one by Weissensteinburg, but my friend said that this way may be better for the wire (less likely to damage it) but I'm not sure. Feedback is always appreciated!
Remember, If you liked it you could always rate it +1 :)
STEP 1: Materials
A utility knife (see pictures)
Your wire
Good lighting
A marker
Scissors*
*Optional (Only needed if your sharp knife can't make it through the wire)
Your wire
Good lighting
A marker
Scissors*
STEP 2: Wire Lengths
Measure out the lengths of wire that you need and cut them. You can use your utility knife, or scissors if the utility knife doesn't make it through. I just used the knife. If you decide to cut using the knife, position your finger/thumb on top of the knife and use the tip of the blade to cut. It will work better that way.
STEP 3: Mark
Using the marker, make a mark about half a cm from the end of the wire on each side. This isn't strictly neccesary but helps you to see where to cut, which is helpful if you have very small wires or bad lighting.
STEP 4: Scoring
Now, begin scoring around the spot you marked. This is where the good lighting begins to become important to see your marks and where you cut. Score around the entire wire and try not to nick the actual wire. The whole key is finding the right amount of pressure. You have to make it so it cuts through but doesn't damage the actual wire. This is easy after a couple of tries. Here is the method I use.
Hold wire down
Apply pressure with knife
Keep pressure applied and turn wire
...Which now brings us to the next step.....
Hold wire down
STEP 5: Tip Removal
Now you should see a tiny bit of copper/what-ever-your-wire-is-made-of peeking through all the way around the wire, like in the picture. If you can see this all the way around, grab the end and pull it off. If not, keep cutting. Look at the pictures if this step is at all confusing.
Now just repeat for the other end, and the other wires.
STEP 6: There You Have It
And there you have it, an easy way to strip wire without wire strippers. If you have any suggestions or problems, please tell me.
54 Comments
MachF 5 years ago
HaremCinema 6 years ago
Thanks for sharing this. As a full time handyman for years I used this exact technique very often (and used it yesterday too as a matter of fact) and can testify that it works wonderfully.
BarbaraS234 6 years ago
SebastianP138 6 years ago
I use a vegetable peeler works fine
wire stripperå 7 years ago
http://b5888888.wixsite.com/ciaojih
AlenL4 7 years ago
http://b5888888.wixsite.com/wirestripper
John T MacF Mood 7 years ago
I use a pocket knife, and have learned how to nick the cover enough to strip the wire without touching the write. Works every time. it takes practrice, but after over 50 years of electronics, it's easy. Try it, you'll find it easy once you master the technicque.
sheriff1200 8 years ago
Myself, I prefer to cut the wire with a razor knife but, instead of cutting the wire all the way around and taking the chance of damaging the actual wire. I cut the wire along it's length and, then peal the wire back as far as I need and, then just clip it off.
majordadsage 8 years ago
Excellent idea.
RebeccaT3 9 years ago
I have a CopperMine Manual Wire machine, which is very great for me. I achieve a best result quickly and easily with this machine when I remove the coating of wires or cables without any hitches. really no hitches. Check out http://www.tulsiny.com/top-10-best-wire-stripping-machines-reviews/ where I buy from here.
GeraldM2 9 years ago
Awesome DIY guide on stripping wire. Although I work alot with wire I have been making a killing lately with my StripMeister Automatc Wire Stripping Machine.
DC4Projects 9 years ago
Easier way: Just tear both ends of the wire(s) with your teeth!
*Make sure to was your mouth after that!*
jonathanmlang 10 years ago
secondplanet 12 years ago
Mayday001 12 years ago
Aar000n3y 16 years ago
Gjdj3 16 years ago
rsk11584 16 years ago
guggenheim 14 years ago
multiplecats 15 years ago
