How to Turn a Old Table Into a Trough Party Table
Intro: How to Turn a Old Table Into a Trough Party Table
I have made one of these in the past and it proved very difficult to get right, It was only after I made it that I thought of better ways to do it. So decided to have another go with this table.
STEP 1: Find an Old Table to Use
I had this old damaged veneer table at home, it had lots of dents and scratches and the ends had been cut off, so I decided to do it as a rustic table and added some distressing all over the table (I used the drill chuck to hit the table gave a nice pattern as well as the screw) to make it look better and not just like a damage table. My son made me the trough out of aluminium to fit into the center. Center the trough and mark out the position.
STEP 2: Cutting Out the Centre for the Ice Trough
I cut the center out using a router. I set up a fence using scrap wood, so it would be easy for me to run the router around with less fuss. I used a 3/16" straight bit in the router. And did small passes with the router at a time.
STEP 3: Add Trough to Table
I lined the trough up with the hole in the table and added some screws to keep it in place. I knew this was not going to be strong enough so I added some wood supports to hold the weight of all the ice and the drinks. I then needed a lip inside the trough for the lid to balance on. I added little hinges that I attached with pop rivets and then just added a piece of wood to give it a better cosmetic look.
STEP 4: Attaching Pull Rings and Supports
I bought these pull rings from a boat shop so that you are able to lift the lid off easier. But then I ran into another issue. Because my table was so long, over 2 meters. The centre lid that I cut out had a bow in the middle when it was put on, so any weight added on the lid would break the lid. So I added some scrap lengths of wood to the underneath to strengthen the lid and stop the bowing in the centre.
STEP 5: Hiding the Plywood
Because my table was plywood and I had exposed a lot of the edges, I used a wood veneer tape to hide the edges and make the table look like wood. This I did using my iron and an old piece of sheet. The veneer was lined up and covered with the old sheet and I used the hot iron to attach it to the table, and used a craft knife to cut away the excess. I then sanded down my table ready for staining.
STEP 6: Staining My Table
After I sanded down the table, I realized that the legs were real wood and had beautiful markings on them and being a big hater of painting furniture when not necessary I decided to go for a two tone color. I used dark mahogany on the base and the trim and Unicorn spit for the color. To get the color I used 3 part blue thunder + 1 part dragon belly and 30% water. I added two coats of varnish and made so simple benches to make the table more appealing to the buyer.
STEP 7: Adding Drainage
To drain the trough after use of all the water, I drilled a small hole and use a cork to block the hole.
To see more of my work to go to www.uniquecreationsbyanita.com
15 Comments
StevenM43 6 years ago
AnitaH25 6 years ago
grannyjones 7 years ago
I can see something like this done on a picnic table. Cool!
AnitaH25 7 years ago
sgsax 7 years ago
Really like the color on the surface. Can't really see the distressing on the top with the bright color. Is it very noticeable in person? Benches look great, too. Got another Instructable for those? Thanks for sharing!
salmansheikh 7 years ago
Jedi_zombie85 7 years ago
Truly inspiring build, top work
Thank you, very nice to hear people like my projects :)
Rideable Entertainment 7 years ago
looks nice :D
Thank you!
4DIYers 7 years ago
Very well done and excellent idea!
Thank you!
