How to Un-seize a Piston: British Seagull Outboard Engine + Change Impeller, Gearbox Oil Seal & Carburetter
Intro: How to Un-seize a Piston: British Seagull Outboard Engine + Change Impeller, Gearbox Oil Seal & Carburetter
How to un-seize a rusty piston using heat and dismantling fluid.
Fully seized 2 stroke Seagull Outboard Engine Restored and Running. Gearbox removal and seal replacement, Water pump / impeller change and carburetor repaired. The principles are the same for most seized piston engines, be it a lawnmower, motorcycle, car or outboard motor as shown here.
Hope you find this video useful. Please remember to share and like it, this really does help more people to find my videos. I look forward to reading your comments. Kind regards Andrew
3 Comments
KD8MSS 6 years ago
Break all the porcelain out of a spark plug. Tap and thread the remaining metal bit and put a grease zerk fitting in it. Install in the engine and he used a brand new lever style grease gun. Start pumping grease to it. At 3000 psi and being grease it will pop right loose.
AndrewKFletcher 6 years ago
Danger is my middle name 9 years ago
This is helpful, thanks for sharing!
