Introduction: How to Use CDS With SkiiiD
A tutorial to develop CDS with skiiiD
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Search or Find a Component
① Type 'CDS' on the search bar or find the CDS on the list.
Step 5: Select CDS
② Select CDS Module
Step 6: Pin Indication and Configuration
then you can see ③ pin indication. (You can configure it.)
*This module has 4 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for CDS Module] in case of Arduino UNO
AO: A0
DO: 2
GND: GND
VCC: 5V
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of CDS Module
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getData()
"Return ADC value from analog data."
getBrightness()
"Set the level corresponding to current CDS value."
isBrighten()
"If brightness is greater than set value, return false. Else, return true."
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkF...
skiiiD user forum: https://www.facebook.com/groups/skiiiD/
Comments are fine too!
