How to Use Gesture APDS9960 With SkiiiD
Introduction: How to Use Gesture APDS9960 With SkiiiD
A tutorial to develop Collision Switch XD206 with skiiiD.
Step 1: Launch SkiiiD
Launch skiiiD and select New button
Step 2: Select Arduino UNO
Select ① Arduino Uno and then click ② OK button
*This is Tutorial, and we use Arduino UNO. Other boards(Mega, Nano) have the same process.
Step 3: Add Component
Click '+' (Add Component Button) to search and select the component.
Step 4: Saerch or Find a Component
① Type 'Gesture' on the search bar or find the Gesture APDS9960 on the list.
Step 5: Select Gesture APDS9960
② Select Gesture APDS9960 Module
Step 6: Pin Indication and Configuration
#4 then you can see ③ pin indication. (You can configure it.)
*This module has 4 pins to connect
skiiiD Editor automatically indicate pin setting *configuration available
[Default Pin Indication for Gesture APDS9960 Module] in case of Arduino UNO
VCC: 3.3V
GND: GND
INT: 2
SDA: A4
SCL: A5
After configuring pins ④ click ADD button on the right below side
Step 7: Check Added Module
⑤ Added Module has appeared on the right panel
Step 8: SkiiiD Code of Gesture APDS9960
skiiiD Code is intuitive function-based codes. This is based on skiiiD libraries
getGesture()
"Return the detected gesture as int."
getColor()
"return the detected color as int."
getBrightness()
"return the detected light's brightness."
getDistance()
"return measured distance between the sensor and the object as cm, mm, inch, or feet."
Step 9: Contact and Feedback
We are working on components and boards libraries. Feel free to use it and feedback us, please. Below is contact methods
email: contact@skiiid.io
twitter: https://twitter.com/skiiiD_official
Youtube: https://www.youtube.com/channel/UCfS2RQL3m3hVoHkF...
skiiiD user forum: https://www.facebook.com/groups/skiiiD/
Comments are fine too!
Be the First to Share
    • Lamps Challenge
      Lamps Challenge
    • Rice & Grains Challenge
    • Puzzles Challenge
      Puzzles Challenge
