Introduction: How to Use Hemp Oil to Seal Your Furniture
Our Hemp Oil is an environmentally-friendly, 100% natural furniture finish. It is completely free of solvents or other chemical additives.
You can use it on raw wood, furniture pieces painted with Country Chic Paint, on leather, or even on wooden floors.
All of the products used in this tutorial can be found on our website, countrychicpaint.com.
Step 1: Prep Your Surface
Before you begin, make sure your surface is clean and dust free. If you’re applying Hemp Oil over top of a piece painted with Country Chic Paint, make sure you give the paint about 12 hours to dry before you begin.
Step 2: Apply a Coat of Hemp Oil
Don’t be alarmed by the color! Hemp Oil is a deep green color, but the color will vary a bit between harvests. When first applied, Hemp Oil will deepen the color of your finish but it will slowly lighten over time as the oil soaks in and cures.
You can use a lint-free rag, or a paintbrush to apply Hemp Oil, but our personal preference is a painting sponge. You don’t need much! Just wipe one thin coat over the surface and let it soak into the finish for 12 hours.
Step 3: Buff It Dry!
Once the Hemp Oil has been left to dry for 12 hours, you can use a dry, lint-free rag to buff away the excess. If you’d like to add more sheen, keep buffing to add a bit more luster to the finish.
For higher traffic pieces like coffee table tops, we recommend adding a second or third coat for optimal durability. Hemp Oil will slowly wear away over time so it’s best to re-apply every 2-3 years as needed.
Since Hemp Oil is an all-natural product with no chemical additives, it can take about four weeks to fully cure. You can of course start using your paint almost right away, but be mindful of the finish and use it gently for the first week.
Step 4: The Effect
Here you can see the immediate difference one coat of Hemp Oil makes over a painted surface or raw wood. Keep in mind that the color will lighten slowly over time.
Step 5: Watch This Video!
In this brand new video tutorial, company co-founder, Rosanne will show you how to apply Hemp Oil to painted or raw wood to give it a beautiful, revitalized finish!
2 Comments
Question 2 years ago on Step 5
Hello , just wondering does the wood finish hemp oil have a shelf life ?
I know the food grade is 12-14 months
Answer 2 years ago
Hi there!
Because our Hemp Oil is not a food grade product, it won't have as limited of a shelf life. If left unsealed it would eventually go rancid I imagine, but I've been using it for years and I've yet to run into problems!
