Introduction: How to Use QBoat Sunny to Build WiFi Applications
In this tutorial, we will use transfer information from DHT11 (connected to LinkIt 7697) to QBoat Sunny via HTTP. Then, the QIoT Suite Application will output the temperature every 30 seconds, and humidity every 60 seconds.
What You’ll Need:
- QBoat Sunny
- MediaTek LinkIt 7697
- DHT11 Temperature and Humidity Sensor
- AP Wireless Router
- Files used: Download Here
Step 1: Create and Setup QIoT Application
Open QIoT Suite > IoT Applications > Import > select test.json
Step 2: Connect LinkIt 7697
Connect the DHT11 to LinkIt 7697.
- GND to GND
- VCC to 3V3
- Signal to P3
Step 3: Open Dht11-wifi.ino in Arduino IDE and Change Network SSID and Password Accordingly
Download and Install the Arduino IDE here.
Step 4: Upload Dht11-wifi.ino to LinkIt 7697 Via Arduino IDE.
Step 5: Open the Serial Monitor (Ctrl + Shift + M). the Serial Monitor Will Show LinkIt’s IP Address. Copy This IP Address
Step 6: Connecting QIoT Suite to LinkIt
Head back to QIoT Suite and double-click the temp node.
Paste the DHT11’s temperature URL into the URL field, then give this node a name.
URL: http://<LinkIt's IP>/temp
Click Done
Step 7: Repeat Step 6, for DHT11’s Humidity URL.
URL: http://<LinkIt's IP>/humi
Click Save.
