Introduction: How to Use Sky3DS Plus to Play All 3DS Games on 3DS 2DS
What is the best flashcard to play 3DS games?
There are countless number of flashcarts currently available to run 3DS games, however which is the best card between them all? The choices range from Gateway 3DS, Supercard DStwo, R4i Gold 3DS and Sky3DS+. If you want to run the most recent 3DS games, then you will need to go with Sky3DS+. Sky3DS+ is currently the only cartridge that is upgrade-able, meaning that once a new 3DS game is released, it will be supported by the Sky3DS+ and most importantly it is compatible with all 3DS devices, regardless of version numbers. All other flashcarts are only compatible with 3DS consoles under version v9.2. The R4i simply supports DS games only and will not run 3DS games.
This article will provide you will a detailed step-by-step guide on how to setup and run your Sky3DS plus to run your 3DS games on your 3DS/3DS XL/2DS. Currently, http://www.stormgadgets.com/shop/sky3ds-plus-sky3ds-play-all-3dsds-roms-on-all-consoles/ is the most popular choice to purchase your Sky3DS+ cart.
You will need the following items in order to complete this tutorial:
- Sky3DS+
- Micro USB Cable
- MicroSD Card (At least 1 GB)
Step 1: Format MicroSD Card
You will need to format your microSD Card, simply insert the card to your PC. Go to ‘My Computer’ and right click on your microSD card and select ‘Format’. Select the file system as FAT32 and the allocation size as 64kb.
Step 2: Download Latest Sky3DS+ Firmware
Visit the Sky3DS website and download the latest firmware that is available. Once you download it, it will be in RAR format, extract the file using WinRAR or any other RAR extraction software. You will find a file called firmware.bin. Copy this file and place it into the root of your microSD card. Eject your microSD card to continue.
Step 3: Update Sky3DS+ to Latest Firmware
Insert your microSD card to your Sky3DS+ cartridge. Insert the micro USB cable to the Sky3DS+ and the other end to your PC/Laptop.
Now the LED light will flash red and will then be blinking green. This should continue for around 10 to 15 seconds. Eject the Sky3DS once the LED is no longer on. You should wait a minute before ejecting, just to be on the safe side. You could damage your card if you eject while the LED light is on.
Your Sky3DS+ is now updated to the latest version.
Step 4: Run 3DS Games on Your Nintentdo 3DS
Transfer .3DS games to the root of your microSD card, the filenames should end in .3DS. Remember that the game must be the same region as your console. Once you have transferred the games onto your microSD card, insert the Sky3DS+ to your console.
Your games will now appear on your 3DS/2DS, use the orange button to change titles.
