How to Use TDA7297 Amplifier IC in Stereo Audio Amplifier Circuit?
Intro: How to Use TDA7297 Amplifier IC in Stereo Audio Amplifier Circuit?
A Stereo Audio amplifier is a simple electronic circuit that boosts a low-power AC audio signal to a level where it is strong enough to be driven by an audio transducer such as a headphone or loudspeaker. Audio amplifiers have proven their worth in today’s electronics, whether it be a simple toy or a complex music production process. So, in Today’s tutorial, we will go through a step-by-step process on how to design a Stereo Audio Amplifier Circuit Using TDA7297 Dual Bridge Amplifier IC.
The heart of this circuit is a TDA7297 amplifier IC. TDA7297 IC is a Stereo dual bridge, Class AB dual-channel audio amplifier. It is available in a compact 15-pin IC package and can operate with 6V to 18V making it suitable for consumer electronics like TV, Radio, Home theater, etc. TDA7297 IC can deliver up to 30W (15+15) of output power, so you can run two 4Ω speakers at 15W each for stereo audio quality.
STEP 1: Design the PCB
Design the PCB using a PCB layout tool such as EasyEDA. After that order the PCB using an online PCB fabrication service such as AllPCB. To learn more about how you can order your first PCB using AllPCB design services please visit their website by clicking here.
STEP 2: PCB Board
Solder all the components on the PCB board.
STEP 3: Connect
Connect the +ve & -ve terminals of the two 4 Ohm loudspeakers with the amplifier output through block connectors . You can also solder a heat sink with the PCB board to reduce temprature.
STEP 4: Circuit Diagram for Stereo Audio Amplifier
Connect the 3.5mm audio jack to an audio source (smartphone). After that, power up & test the circuit.
Working Explanation
This circuit can take dual audio input & can project the output on two separate 15W 4 Ohm speakers. The working of this circuit is as follows, Audio input from a device such as a smartphone is taken at the inverting inputs (pin 4 & 12) of the TDA7297 IC. Here, two 220nF coupling capacitor is used to block the DC component of the signal allowing only the AC component to pass through. The circuit allows you to adjust the intensity of the output sound by adjusting the MUTE & ST-BY pin using a 10uF & 50K pot RC combination. The 15W 4 ohm speakers can be connected to the two outputs provided on the IC. You can use a 12V battery to operate this circuit smoothly.
Applications
Usually used in small toys, media players & small electronic projects. Also widely used in the entertainment industry for live music production & recording
jessyratfink 2 years ago
We’re glad you want to share something with the Instructables community!
And we’re here to help you out.
In order to be published live on the site and be eligible to enter a contest, an Instructable must consist of the following things:
- Multiple written steps showing how you made your project
- Photos in each step
- Only your own original images
Check out our free online class that walks you through how to write an Instructable: https://www.instructables.com/class/How-to-Write-an-Instructable-Class/
Beyond making your Instructable simply publishable, this guide (https://www.instructables.com/id/How-to-Create-a-Feature-Worthy-Instructable/) explains what is required to have your Instructables featured by our site editors. It’s very helpful, and definitely worth checking out.
We would love to review your project again after you have made the necessary edits, and we will publish your project if it is eligible.
If you have any questions, please feel free to ask right here or send us an email to service@instructables.com.
Best,
Instructables Community Manager
