Introduction: How to Use a Combat Application Tourniquet (CAT)
The Combat Application Tourniquet (CAT) is an effective tool to help control severe blood loss from body's extremities. If used correctly, the CAT has the ability to save lives. A general misconception of the CAT is that it will result in the casualty requiring amputation of their extremity; this is false. Amputation is more often required as a result of the injury itself, not because of the tourniquet.
This Instructable will teach you about the parts of the CAT, correct placement on the extremity, and how to secure it in place
DISCLAIMER:The CAT should be a LAST RESORT for blood control management. Applying direct pressure to the injury and elevating the extremity above the heart should be attempted prior to utilizing the CAT.
MATERIAL(S) REQUIRED:1 Combat Application Tourniquet (U.S. military members are usually issued 2 while tasked for deployment, however, they are available for purchase through online vendors).
Step 1: CAT Terminology
- Friction Adapter Buckle
- Windlass Rod
- Windlass Clip
- Windlass Strap
- Omni-Tape Band
Step 2: Place Injured Extremity Through the Loop of the Omni-Tape Band
NOTE: You may have to thread the Omni-Tape Band through the Friction Adapter Buckle if it was not done so already.
Step 3: Place the CAT Approximately 2-4 Inches ABOVE the Injury
- You can use your fingers to estimate the distance (generally 2-4 fingers width should be sufficient)
Step 4: Once Placement of CAT Is Correct, Tighten the Omni-Tape Band Then Secure It Onto Itself With the Velcro
Step 5: Twist the Windlass Rod NO MORE THAN 3 TIMES, Then Insert It Into the Windlass Clip
- Twisting the Windlass Rod more than 3 times may cause it to break.
- If you can twist the Windlass Rod more than 3 times, repeat the previous step and pull the Omni-Tape Band tighter.
6 Comments
1 year ago
Actually you should put it as high as possible to the limb because if it punctures a artery it can go past 4 inches and possible keep bleeding so make sure as high as possible and never on a joint take this advice it saves lives
Reply 5 months ago
This is correct - I was taught this in the police academy during tac med.
Tip 2 years ago on Step 5
you should check pulse
7 years ago
Great work!
7 years ago
Nice work!
7 years ago
It's one of those things that you hope you never need but you will be really glad that you have it if you do need it.
