Introduction: How to Wrap a Veterinary Surgical Pack
How to clean, organize, wrap and sterilize a basic surgical pack for veterinary use.
Step 1: Identify Hazards
Before touching any instruments, identify “sharps” (needles, scalpel blades) that may need to be removed from the pack.
Step 2: Dispose of Hazards
Remove scalpel blade from handle and place blades and needles in an appropriate sharps disposal container. IMPORTANT: Always remove pull them away from your body. Always dispose sharps of in a sharps container.
Step 3: Soak Instruments
Place instruments in soak with water and instrument soap to prepare them to go in the ultrasonic cleaner. Allow to soak for 5-10 minutes.
Step 4: Place Instruments in Ultrasonic Cleaner
Remove instruments from soak and scrub, then place in ultrasonic cleaner.
Step 5: Start Ultrasonic Cleaner
Set cleaner to desired settings, then start.
Step 6: Dry Instruments
Once the cleaner is finished, remove instrument basket and place instruments out to dry. IMPORTANT: Leave instruments open to dry. Instruments may be patted dry to quicken this process.
Step 7: Sort Instruments
Once instruments are dry, close instruments and sort straight tipped instruments, curved tipped instruments, and other instruments.
Step 8: Organize Instruments
Organize straight instruments biggest to smallest and curved instruments biggest to smallest side the spay hook through the handles.
Step 9: Prepare Instruments for Wrapping
Lay instruments onto two layers of drapes. Drapes should be laid out so that points are out up, down, left and right (diamond, not square). Instruments should be laying square in the middle. Other instruments should be arranged around instruments on spay hook to create a square.
Step 10: Prepare Pack to Wrap
Place an accordion folded fenestrated drape and three stacks of gauze (approximate height of drape) into a square on top on instruments.
Step 11: Begin Wrapping
Pull the corner of the drape pointing towards you up away from you, then, leaving enough the fabric over the instruments to cover them pull the excess fabric pointing back down towards you.
Step 12: Continue Wrapping
Holding the first fold down, pull one side across to cover the instruments (in the same way the bottom was pulled across) and then pull excess fabric back the other direction. Repeat this for the other side.
Step 13: Finish Wrapping
Holding all these folds down, only the top should be left unfolded. This can now be pulled down and tucked into the “pocket” created by the right and left sides.
Step 14: Wrap Second Layer
Place a tri-folded huck towel over the first layer. Wrap the second drape layer as you did the first.
Step 15: Label Pack
Using instrument tape, label your pack as appropriate.
Step 16: Begin Autoclave
Place in the autoclave on appropriate settings and start.
Step 17: Vent Autoclave
Open the autoclave to vent to dry when the machine indicates.
Step 18:
When the dry cycle is complete, remove pack from autoclave. Insure that the instrument tape has turned striped to indicate that the place has been effectively sterilized. If it has not, the pack will need to be run again.
