How to Make a Face Protection Mask Shield With a Plastic Bottle
Intro: How to Make a Face Protection Mask Shield With a Plastic Bottle
Hello,
Here is a video that shows how to make a protective mask for the face.
It is mainly intended for nursing staff or caregivers with coronavirus patients
This project was to be proposed in countries where raw materials are not readily available, but given the circumstances and the massive shortage of protective masks, it will certainly be useful around the world.
The tools and supplies necessary for its manufacture are widely and easily accessible.
It takes about 5-10 minutes.
Take care of yourself, stay at home.
Dragon Rouge
STEP 1: Draw the Shield
Take a transparent plastic bottle with a large surface without ribs.
Draw two lines with the pen to preserve the largest possible surface.
STEP 2: Cut the Shield
Look at where the glue and the molding junction are.
Trace with a pen so that they are not in the field of vision.
Cut on the lines with a pair of scissors.
STEP 3: Cut the Headband
Take the neck portion of the bottle.
Draw a strip 3 cm wide. It will be the headband.
Cut with scissors.
STEP 4: Set Up the Headband on the Shield
Set up the headband on the shield with tweezers, keeping a space between the headband and the shield
STEP 5: Adjustment Bands
Take another bottle.
Draw two 3 cm strips.
Cut them with the scissors.
STEP 6: Mount the Adjustment Bands
Mount the adjustment bands so that they correspond with the ends of the headband on the shield.
Pinch them with the tweezers.
STEP 7: Drilling With a Lighter and a Paper Clip
With a lighter and a paper clip pierce the three layers by making three holes placed in a triangle.
Do the same on the other side.
STEP 8: Drill the Adjustement Band
drill two holes 1 cm apart on one of the
adjustment bands. Drill holes 1 cm apart along the length of the other strip.
STEP 9: Sewing With Wire
Sewing with wire
Sew with wire using the three holes to pass.
STEP 10: Adjust on the Head
Adjust on the head and sew with a wire using the two holes.
STEP 11: Tadaaaa... the Shield Mask Is Finished
the shield mask is finished
