How to Build Speargun for Less Than $10
Intro: How to Build Speargun for Less Than $10
Simple, Cheap, and Effective Hawaiian style spearfishing gun.
STEP 1: Materials
2 ft Rubber Surgical grade Tubing or Exercise bands ($3-5)
Small Section of PVC 1/2in - 1in in Diameter ($2)
1 Youth Arrow with safety tip ($3)
4 - Zip ties (.50)
Total cost for these materials should be less than 10 bucks, if not free. All these things are pretty easy to find.
4 - Zip ties (.50)
STEP 2: Assembly
Take both ends of the rubber tubbing and place each side evenly onto the PVC pipe. Once in place tighten a zip tie around the the rubber tubbing and PVC, leave around a 1/2 inch of rubber tubbing at the end. Now fold the tubbing back and place another zip tie. This should hold everything nicely in place. I added a few more zip ties toward the top of the PVC, just for good measure.
STEP 3: Testing
Dry fire it a few times before you add the arrow. It will work similar to a sling shot holding the tail of the arrow in the center of the rubber tubing. Draw back and then release.
Please be safe!! I have a one eyed uncle that can testify to the fact that arrows are dangerous.
8 Comments
The_Modder 6 years ago
cazlab 8 years ago
this is not a speargun.
it is a hawaiin sling.
we don't call machetes pocket knives or scooters motorcycles or gliders airplanes.
this community has gotten pretty fast and loose with what words mean over the last couple of years.
BakerV 7 years ago
If you are wondering, a hawian sling was called a speargun before losers added a trigger
JonathanH14 8 years ago
This is a good basic concept for an antenna launcher--radio operators use it to put a line high on a tree branch, then pull up the antenna wire. The advantage to this small design is portability. Instead of arrows, one would use a weighted blunt dowel, or perhaps some sort of arrow. I also wonder why such a large diameter piece of PVC was used--but it would allow a better grip, I suppose. Anyway, a good start for something useful.
mwhit13 10 years ago
Just curious. at least theres one Hawaiian sling on here.
cybercoho72 12 years ago
bubba j 14 years ago
you coul get sued if you don't add I AM NOT RESPONIPLE FOR WHAT YOU DO WITH THIS SPEAR SHOOTER so some one dosn't shoot thier neibors cat
