How to Change a Tire on a 1993 Ford F150 Truck
Intro: How to Change a Tire on a 1993 Ford F150 Truck
So you got a flat tire while driving home for Christmas. What do you do? Here is how you change your tire so you can make it home in time to open presents.
STEP 1: Materials:
-Large Phillips head screwdriver
-Jack
-Tire Iron
-Spare Tire
-Jack
-Tire Iron
-Spare Tire
STEP 2: Retrieve Jack and Tire Iron From Beneath the Passenger Side of the Hood.
(see figure 1)
STEP 3: Remove Lug Nut Cover Using Philips Head Screwdriver.
(see figure 2)
STEP 4: Loosen Lug Nuts Using Tire Iron.
Loosen lug nuts until they are finger tight.
STEP 5: Retrieve Spare Tire From Beneath Truck Bed.
a. Pull J hook towards rear bumper so that washer slips through large hole, releasing the spare tire carrier. (see figure 3)
b. Unscrew tire bolt and remove tire.
STEP 6: Place Jack Beneath Front Axel and Insert Tire Iron.
(see figure 4)
STEP 7: Raise Truck With Jack.
rotate tire iron clockwise
STEP 8: Remove Lug Nuts and Remove Tire.
a. Use tire iron if necessary.
b. Be sure to place lug nuts where you can find them again.
STEP 9: Place Spare Tire on Hub and Replace Lug Nuts.
Tighten lug nuts firmly with tire iron.
STEP 10: Lower Jack With Tire Iron.
Rotate tire iron counter clockwise.
STEP 11: Replace Jack and Tire Iron in Engine Compartment.
Take flat tire to be fixed.
6 Comments
enonorez 9 years ago
Is there a special tool to remove what labled as the tire bolt?
jakob356 16 years ago
It tells you how to change the WHEEL. Not the TIRE.
And changing the wheel is always described in the instruction manual for the vehicle.
georion 12 years ago
yo man 14 years ago
LinuxH4x0r 16 years ago
