How to Change Engine Oil for Saab 9-3
Intro: How to Change Engine Oil for Saab 9-3
Safety Issue
If you do not have any background knowledge of repair and maintenance, please do not try yourself. This might be the most dangerous
try. This also could bring more cost to repair that one mistake can make. Safety equipment such as goggles and gloves is required, and
please do not work if you are in condition of consumption of alcohol and medication and illness. Once again, please read this carefully if
you are beyond knowledge of repair, and working with a vehicle expert is recommended.
In addition, before start, make sure the vehicle is cooled down if the vehicle was driven while ago.
STEP 1: Get Prepared
First, in order to start changing engine oil, engine oil, filter and new gasket for drain bolt are needed. A receptacle, the tool for oil
filter cover and wretch for the tool are also needed as the figure above shows. Later, to lift a vehicle, a jack or lift and a jack stand are
required.
required.
STEP 2: Open the Hood
You can start with opening the hood. As most vehicles do, Saab 9-3 series has a lever on the left side below the steering to open the
hood. Pull the lever, then it allows you to open the hood.
STEP 3: Remove the Engine Cover
To remove the engine cover, a torx driver is needed. Do not worry even though you do not have a torx driver. Saab 9-3 series has a torx
driver in the trunk where a spare tire is located.
STEP 4: Carefully Move the Atmosphere Pressure Sensor and Manifold Absolute Pressure Sensor Cables That Blocks the Oil Filter Cover Aside
You can just move aside the sensor cables to reach the oil filter cover. If you need more space, you can disconnect the cables.
STEP 5: Open the Oil Filter Cover With the Oil Filter Tool.
If you reach to the oil filter cover, attach the tool to the cover. Then, open the cover using a wretch.
STEP 6: Raise the Vehicle With a Jack or Lift
This is the most important part. If you are not sure, please do not try and ask someone who knows Saab well.
For changing engine oil it is not necessary to lift up the entire vehicle. That is, lifting on the right front side is enough to change engine
oil. If you see each side panel under door carefully, the arrow on the side panel of Saab 9-3 series tells you where to lift up.
STEP 7: Place a Jack Stand for Safety
Do not try to go underneath without placing a jack stand. You have to place a jack stand for safety issue on either frame or control arm.
STEP 8: Place a Receptacle Under Oil Pan
Do not disposal the used oil. Please take the used oil to recycle center where collects used oil.
STEP 9: Remove the Drain Bolt and Drain the Engine Oil
Please remove the bolt slowly. The engine oil could be drained suddenly.
STEP 10: Wait Until All the Engine Oil Is Drained
Wait until the engine oil is drained completely from the oil pan.
STEP 11: Plug the Drain Bolt Back With New Gasket
Tightening torque for the drain bolt is 25Nm (18lbf ft)
STEP 12: Lower the Vehicle
Make sure take everything out from underneath before lower the vehicle.
STEP 13: Fit New Oil Filter With O-ring
Before fit new oil filter and o-ring, make sure lubricate them.
STEP 14: Fill New Engine Oil
Saab 9-3 series takes 6.7qt to 7.0qt synthetic oil with the viscosity of 0W-40
STEP 15: Start the Engine and Let It Run 30 Seconds
STEP 16: Check the Oil Level After 3-5mins and Top Up With Oil If You Need
Avoid top up the oil over maximum capacity. It will affect not only the performance but also durability of the engine.
STEP 17: Fit the Engine Cover
Fit the engine cover with a torx driver, and make sure wipe out if the oil was spilt.
STEP 18: Done!
Changing engine oil is done! Make sure the used oil should be taken to recycle center, and clean the area you worked on.
