How to Climb a Tree (using Only Rope!) the Fun/simple Way
Intro: How to Climb a Tree (using Only Rope!) the Fun/simple Way
In this instructable, I will be showing how to climb a tree using only rope, a carabiner, muscle strenght, and time.
I am not an experienced or trained climber. Don't tell me that I'm not either. I'm only showing you how to climb how I like to climb. It is the easiest, most relaxing, simplest way.
WEAR A HELMET (I didn't)
It is divided into 6 steps.
1. Equipment
2. Getting the rope into the tree
3. The harness
4. The knots
5. Climbing
6. Getting back down
_-_ -_ -_ -_ -_ -_-_ -_ -_-_ -_ -_-_ -_ -_
|ALL VIDEOS ARE EMBEDED |
|THE HARNESS VIDEO IS here:https://www.instructables.com/id/SV072LCFV4LS8QN/
|-_ -_ -_-_ -_ -_-_ -_ -_-_ -_ -_-_ -_ -_- |
1. Equipment
3. The harness
4. The knots
5. Climbing
STEP 1: Equipment
These are the minimum requirements to climb a tree.
1. Have at least one locking carabiner. Make sure you have one that is made for climbing! The ones that I have cost $7 each, bought at REI. They can hold 25kN (That's about 5,600 pounds)
2. Have about 15 feet of 3/4 inch rope. This will be used for the harness. It is important that is thick, because this makes for a more comfortable, satisfying harness (Unless you have a real harness)
3. Depending on the height of your tree, you will need rope that is as long as twice the height of the tree. (Use equation below) I didn't use real climbing rope, but I recommend that you do. The rope I have can hold 350 pounds. It gets the job done.
My equation!
h = height of tree
r = length of rope needed
r = 2h + 10 (IE. 30' tall tree = at least 70' of rope)
4. A tree of course! Make sure that it is some sort of oak. Oaks are very strong, large trees, with few branches at their bases.
Find a good-sized tree that is about 25-50' tall. My tree is about 30'. (I would also find a tree that isn't over a cement driveway)
My equation!
h = height of tree
STEP 2: Get the Rope in the Tree.
I'm not going to show you how to get your rope in the tree :-(
But, I will say that is extremely easy if you have a tree in a good location, and the branch isn't more than 50' high (You should start low anyways)
There's a great instrucatable here https://www.instructables.com/id/How-to-get-a-rope-into-a-tree-without-climbing-it/
Find some sort of weight. (I used a roll of duct tape, but the heavier the better). Tie your rope around it, and swing it until it wraps around the branch you want.
Once in the tree, get slack in the rope and "whip" the rope. You'll know what I mean. It will be your first instinct. You do this foot by foot until the hanging end with the weight comes down to your level.
STEP 3: The Harness
This is a very important step, and it is crucial that you get it right.
The comfort really depends on the rope and positioning
I am using a rope harness called the swiss seat. It is a very common harness. If my pictures and tutorial are confusing, you can find it on Google somewhere. It is a very common search.
Follow along with the pictures.
Harness Video
Harness Video
STEP 4: The Knots
There are only two knots that we'll be tying.
1. I'm not sure if it has a name, but I didn't make it up. It's a real knot
2. The Blake's hitch. The best climbing hitch for our purposes.
Follow the pictures once again. The first is the noname. The second is the Blake's Hitch
Once again, if you can't figure it out from the pictures, go to Google. There are plenty of sites that show how to make knots
STEP 5: CLIMBING(Finally)
Ok. Let's start to climb. It is very simple. It takes several minutes, but then you start to get in the rhythm.
1. Wrap your hand around the rope that is hanging down. Don't wrap excessively, just once, enough to have a good comfortable grip.
2. Pull down on that rope. The goal is not to have your weight on the rope above you, but the rope you are pulling down. It takes a bit of strength, and it's something that everybody can do easily, unless you're doing it wrong. (There is a video below)
3. You probably used two hands to pull the first rope down. If you did it right you moved up about 6 inches ( after a while it isn't that bad). Now. you need to hold the rope you pulled down held down below your waist, or however far you pulled. Hopefully, it will sort of lock, and you can slide up you're Blake's hitch up with your left hand as far as you can. From there, the Blake's hitch should do its magic, and keep you held in place.
4. Repeat
If you couldn't get it by reading, look at the pictures, and watch the video(The video's focus got a little messed up, but you can see better
VIDEOS:
4. Repeat
VIDEOS:
STEP 6: AH! I'm Stuck! Get Me Back Down!
Calm down! It's really easy!
Grab the hitch. Pull down in the top. See? Just make sure you do it slowly, and at intervals to prevent the rope from melting, and the branch from burning!
Watch the video once again.
And there are two other video's that I just decided to dump on this step.
Videos:
Videos:
220 Comments
LauraC198 5 years ago
Wow, great job! As a fellow tree climber, I am deeply impressed. Great instructable. Happy climbing!
hxwhxw 12 years ago
nice Instructable
dkoriss1 6 years ago
...same like if the you are not careful and instead to choose a pool with water to dive in, you choose one with no water in, ..to dive in, ...common sense is mandatory in every action of our life.
NathantheGray 7 years ago
Teslaling 12 years ago
2. You hit the ground with a thump sound!
3. You DON'T hit the ground with any snapping or crushing noises!
4. You say OUCH!
5. You find a bigger branch or lighter climber!
CharlesChristopher 10 years ago
Isn't this harness tie also called a "Swiss Seat?"
TheBestUsernameEver 8 years ago
i HAVE no clue
sco97 10 years ago
This is a very good instructable and I think it awesome that your getting into ropes. I'm a rope access tech. and I think it is great that your getting into this type of activity. One thing I would recommend is using an some type of anchor knot instead of a girth hitch (the unnamed knot). A figure 8 is usually the standard because it is very strong (won't untie itself) and effecient (doesn't weaken the rope much. One thing to note is every knot will weaken the rope to some extent you just need to do some research) it is also easy to inspect. Also props for using a swiss seat as those are not the most comfortable harnesses in the world. One thing you might want to consider is using tubular webbing to tie hasty harness instead if you don't want to buy one. It's more comfortable (in my opinion) and when tied with a water knot very strong.
Keep up to good work dude and happy climbing!!!
bill2believe 14 years ago
louieaw 14 years ago
maestro8 14 years ago
roth_wyatt 10 years ago
jtpoutdoor 14 years ago
ducktape.mac 13 years ago
Speedmite 14 years ago
PKTraceur 14 years ago
