How to Climb Up Walls
Intro: How to Climb Up Walls
I would recommend watching the youtube video before reading the rest of this instructable.
STEP 1: Materials
There are a few materials needed because this instructable is rather an easy one. However every material is important. The pictures below show most of the materials.
2 vacuums (preferably handheld or canister because they are light)
2 tubes that can fit from a vacuum to a vacuum glove
6 by 1/2 screws with washers
2 pieces of wood, the larger the area, the more weight it can hold( but be careful, the wood can get very heavy )
rubber to fit around the piece of wood
2 handles
tape
Most of the materials can be found at Lowes.
STEP 2: Get the Wood Ready
You can then drill the handles in.
STEP 3: Get the Rubber In
STEP 4: Connect the Vacuum to the Vacuum Glove
STEP 5: Finish
Thank you!
29 Comments
YES LUJAIN 7 years ago
Trippinhero 7 years ago
dipayaninblue 8 years ago
How much watt vacuum cleaner needed for this?
blackboard 12 years ago
Football viking boy 12 years ago
_Scratch_ 13 years ago
Football viking boy 13 years ago
imthatguy1125 13 years ago
sugarhi911 14 years ago
Football viking boy 14 years ago
dragonsniper 13 years ago
Guii 13 years ago
MichelMoermans 13 years ago
Getting it off the wall is rather easy, turn the vacuum off.
So if you want to climb walls you should make two of these and put the power buttons of each vacuum on the wood itself. That way you can turn it on and off with your hand.
so climbing would go like, attatch one to the wall by putput it a little higher. then the second one and so on....
Michel
