How to Convert Medical Scan Data Into a 3D Printable Model (also, Dinosaurs!)
Intro: How to Convert Medical Scan Data Into a 3D Printable Model (also, Dinosaurs!)
STEP 1: Get the Software
I'll be using a software package called Osirix, which is designed for medical imaging. Download and install the free version from here. It is available for Mac only, if you are using a PC check out a similar package called Invesalius, developed by the Brazilian government and made available for free.
Update: There is an open-source fork of Osirix, called the Horos Project. Use this instead, and consider donating to the project: https://horosproject.org/download-horos/
We'll also be using Meshlab and Netfabb Studio Basic (the download link is hidden on the right of the page), so go ahead and download those too while you're at it. It's all free.
STEP 2: Get the Scan Data
For the purposes of this example, I'm using the Euoplocephalus skull from the Witmer lab at Ohio University. Download it here and unzip the .zip file.
STEP 3: Get the Scan Data Into Osirix
Tip: when the FOLDER name is selected in the dialog, press the Open button, and Osirix will load all the files contained in the folder.
Another tip: It will ask you whether to Copy or Link the files - use Copy, that way Osirix will copy the files to its own database, and you can delete the downloaded .zip file and the copies of the DICOM data.
STEP 4: Open the Scan Data in a 3D View
You will get a warning message about the software not being medically certified, proceed anyway, the patient in this case has been dead for 65 million years.
To open it in a 3D view, look in the top toolbar for a button with a gear labelled 2D/3D. It is a drop-down menu, you want 3D Surface Rendering. Accept the defaults, and wait a bit, you'll get a 3D view of your skull. You can move it around by dragging on the view cube.
STEP 5: Export Scan As 3D Model
STEP 6: Clean Up the Model
Load up your STL or OBJ file that you have exported in the previous step.
You'll notice that there are some loose bits floating around, and that the texture of the model seems to reflect the resolution of the scan (noticeable as a kind of stair-stepping effect).
To clean up the loose bits, turn the model so that the loose parts don't overlap any part of the skull, and use the rectangular selection tool to select them, then delete them using the filter menu.
To smooth it, go to the Filters menu, and go to the Smooth sub-menu. Choose the Laplacian Smooth filter. When you open it, change the parameter for Smoothing Steps from 3 to 1. (Otherwise it will be too smooth and "blobby"). Apply it. You should notice a dramatic improvement in surface texture.
Go to the File menu and Export the Mesh. You can export as STL or OBJ, though generally OBJ files seem to be more robust when used in other tools. Add a suffix to the file name to differentiate it from the file you exported from Osirix - I generally add "-smooth" to the filename.
STEP 7: Prepare for Printing
Start up Netfabb Studio Basic, and import your cleaned up STL (or OBJ) by going to the Project menu and choosing Open.
Use the View menu to rotate the part until you can see it in the most useful orientation for making the cut. In this case, I want to cut it into a front and back piece, so I am seeing the skull from below. Using the XYZ sliders on the right, choose where you want the cut to go. Select the Cut and Execute Cut buttons as appropriate. Make sure the Triangulate Cuts checkbox is marked, so that it will fill in the cut surfaces.
The model is now cut into two parts. Select each part in turn, and using the Part menu, export each as an STL.
STEP 8: Print It!
Top tip: Make sure that you do not allow Makerware to automatically scale your parts - wait for them both to be loaded, select both, and scale them at the same time. Otherwise the two halves won't match!
Depending on your model, you may or may not need to enable support material. Your call.
Once printed, glue the halves together, take a picture of it, and enjoy!
58 Comments
nissim.hadar 7 years ago
If any one is interested - I am the VP of Technology for a company doing 3D visualization of DICOM imagery, that is used today for planning and supporting brain surgery.
Our website is surgicaltheater.net. My mail is nhadar@surgicaltheater.net.
EG_Little 5 years ago
This work is an incredible development. I am really interested to learn more about your process, so I'll send you an email. I'm a student at City College of New York, and I'm working on making a 3D model of my brain from an MRI.
Best,
Elizabeth
nissim.hadar 5 years ago
TrợĐ 6 years ago
Hello,
We are a medical equipment company in Viet Nam. We are looking for 3D printer which can print from MRI or CT scans. So do you provide that printer? Or you just doing printing service?
Pls contact me by email: thuongch@maytrothinhthienduc.com.vn
Kiteman 6 years ago
This website is a "how to make things" website, not a sales site.
This project should allow you to turn your scan data into a file that most 3d printers can use - look for a printer that can produce the resolution you need in materials suitable for medical uses.
These articles might help:
https://makezine.com/?s=3d+printer+review&post_typ...
jeromeb13 8 years ago
hello ,
i m a laparoscopic surgeon . that is for sure that 3 D printing could help us before the surgery and also to train our resident in what we call lap trainer . but we need to print other things than just the shape of the organ . does anyone want to work with me to be able to print also artery-veins inside and find a way to make it more real for the training and more usefull than just shape for surgery .
SkirmishersS 8 years ago
I am a cross sectional radiographer in the UK. I have successfully created a skull model from an x-ray phantom. I have built my own 3d delta printer and I am involved in developing a new delta printer. I am very keen to get in to bio fabrication. I am very interested in finding medical applications for 3d printing, and working with others interested in this new field. I use GE and Philips MRI scanners at work and GE CT scanner. We also have a vascular fluro room. Please contact me if I can be of any help. I also have a physics degree and programming skills.
SkirmishersS 6 years ago
Several people have written to me asking for CT and MRI datasets. I can not provide you with such data sets for legal and ethical reasons.
There are CT scan data sets online
https://www.dicomlibrary.com/
http://www.osirix-viewer.com/resources/dicom-image...
You might also be able to get human data sets from here http://www.ukbiobank.ac.uk/ but it's probably going to be expensive.
Note animal CT scans have no such restrictions.
HimanshuR36 7 years ago
Please send me on himansurajput1@gmail.com
I want ct scan data for PHD Research
ManarshhjotS 7 years ago
Hello,
I recently handled a case in which I modeled the walls of heart for visualizing the shape of the hole and also the aortic arch for a patient. I would like to work on other projects. Please feel free to drop a mail at manarshhjot.singh@gmail.com
ManarshhjotS 8 years ago
Hello Jerome,
I have a masters degree in CAD/CAM Engineering and I would be very interested in working with you. Please feel free to drop a mail at manarshhjot.singh@gmail.com
DaveW126 7 years ago
I am also interested in this project. We are the leader in tangible user interface for stereoscopic objects. Please contact me at intouch@3dinow.com.
Thank you,
Dave Woods
Founder 3Di LLC
I am creating 3D stereoscopic software which would enable touch interaction. Please visit my website at 3DiNow.com.
I am looking for people in the medical field to help bridge my tangible user interface3 with the medical field.
Please contact me so we can see if a collaboration would be mutually beneficial.
Thank you,
David P. Woods
Founder 3Di
571-414-9698
OliverG27 8 years ago
I had cancer in my intestine, and had it removed , he part of my intestine removed . And 3D printed and using stemcells to grow new intestine, Dr gave me 3 months to live back in nov 2015 now fit
adamtimm1 8 years ago
Jerome, that is exactly what I am attempting to arrive at. I am a respiratory therapist and recognize the medical uses of 3D printing. Please feel free to contact me at adamtimm1@msn.com. I am still getting the hang of this printer but I have a huge print volume bed and can easily get a set of lungs or heart etc. I was planning in a few months to start marketing to surgeons and other specialists. Currently, I am practicing using ABS filament but I have access to nylons of several types which can give you some textural feel and one that can make clothing or shoes. I would like to talk with you.
nrainey 7 years ago
hello all,
does anyone have methodology, platform, ect. for non irradiating medical imaging i.e. 3D ultrasound DICOM to 3D printable format?
BahaA6 7 years ago
We are planning this for MakePrintable, you will basically be able to upload the file and get a 3D printable version in a couple of minutes and a couple of clicks. would love to connect with you so that I can understand more how we can streamline the process for medical uses.
