Introduction: How to Crochet a Nintendo DS Case (for the Lion Brand Yarn Challenge)
This is the case I came up with for my Nintendo DS. It's got 6 game pockets and a strap to hold the DS in place. I used Caron Simply Soft in plum wine and chocolate (Sorry, Lion! I didn't know I was going to submit this to a Lion-sponsored contest or I would've used Vanna White yarn), plus some scrap white yarn and black embroidery floss. I used a size F hook.
I made the back with the pockets first. I just crocheted in the front of the stitches and left the back loop to start the pockets in. Then I sewed up the sides.
Then I made the front (which is slightly larger to wrap around the sides) and sewed it to the back and up the sides. Then the real inspiration struck and I decided to add the mushrooms. I did them in two pieces and used the very long tail I left from the stems to make the spots.
The strap was about 12 ch or so long with a buttonhole.
And that's it! For a more detailed pattern, leave a comment or message me or whatever you do on instructables (I'm new here). Hope you like it!
Edit: Here is the actual pattern. Sorry I held off for so long!
Back
1. With MC ch 31. Turn.
2. Sc in each ch across. Ch 1. Turn. (30 st)
3. Sc in next 2 sc *(Sc in the front loop only of the next 8 sc). Sc in next sc. Repeat from * twice. Sc in next 2 sc. Ch 1. Turn. (30 st)
4-9. Sc in each sc across. Ch 1. Turn. (30 st)
10. Repeat 3, but stitch in the back loop of the stitches this time.
11.-15 Repeat 4-9. End off, leaving very long sewing length.
Front
1. With MC, ch 35. Turn.
2-18. Sc in each sc across. Ch 1. Turn. (34 st)
On last row, end off and weave in end.
Pockets
1. With CC, join in remaining loops you didn't use in steps 3 and 10. Join in first loop. Ch 1, sc in same loop. Sc 1 in each loop across. Ch 1. Turn. (8 st)
2.-6. Sc in each sc across. Ch 1. Turn (8 st)
7. Repeat for each set of loops on back. 6 total.
Then we get to sew everything on/together! With a yarn needle and with the piece turned inside out, sew sides and bottom of front and back together. Sew sides of pockets down.
Strap
1. Ch 12. Turn.
2. Sc in each sc across until the last sc. Work 6 sc into last sc. (Adjust according to button size). Turn. (18 st)
3. Sc in each sc across. End off with sewing length (18 st)
Sew to inside of back with yarn needle. Sew button on front according to strap length (mine was about 1 1/2")
Mushroom
I worked this in two pieces. I did the top from top to bottom. I sewed the bottom on the front first and left a very long tail on the back. I then used the tail to make the spots.
Back
Front
Pockets
Strap
1. Ch 12. Turn.
Mushroom
Back
Front
Pockets
Strap
1. Ch 12. Turn.
Mushroom
Back
Front
Pockets
Strap
1. Ch 12. Turn.
Mushroom
