How to Cure a Sore Throat
Intro: How to Cure a Sore Throat
Tired of your throat always hurting because your tonsils turning big?
dont worry!!!!!!!!!!!!!!!!!!
all you need to do is GURGLE with salted water.(dont forget to mix salt and water)
STEP 1: Gurgle Em Up
You need:
a glass o'water
salt
after you get the ingredients,mix them and then gurgle
it may taste funky,but it is very ....like we indonesians say"wueeeh",but its the only way
a glass o'water
salt
bofthem 16 years ago
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
https://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
