How to Cut a Sponge to Cover Filter Intake
Intro: How to Cut a Sponge to Cover Filter Intake
Hi, this is a instructable on "how to cut a sponge to cover filter intake", this is for aquariums.
this is the sponge I'm using
supplies: a bucket or a large bowl, a couple paper towels or a small towel, a filter sponge.
tools: a pair of sharp scissors.
STEP 1: Measuring,preping, and Cutting
so you should measure your intake tube for your HangOnBack filter, and you should measure how far high you want your sponge to go up the tube. after you complete above step, find out how many inches/centimeters it is cut a small slit that far up from the bottom of your sponge.
and then when you made a slit to mark the thing, cut it all the way around. then once you make sure it is kinda evenly cut around, you can cut all the way thru. when that's done you should trim the top of the measured part to be even.
STEP 2: Step 2: Cutin and Slimin, the Sides.
so after you've done the first step and cut it to the height you want, you can see how wide you want it and you can do the slit thing again to see how wide it will be, and then start to cut all the way down. and REMEMBER CHECK to see if its EVEN because I messed up on one part and almost cut into the hole for the intake tube. when you see that your cutting even go ahead and cut all the way thru.
STEP 3: Step 3: Final Trimmings
ok so almost done just need to do final trimmings and stuff, I trimmed the sides that will be facing front, so there kinda rounded. i know that this is probably unorganized and done wrong but this is my first instructable so im still learning.
well that's all folks.
5 Comments
aquariumlover10 9 years ago
h and if anyone here's is looking for a good aquarium forum, www.aquaticcommunity.com and www.aquaticenthusiast.com are both good. If you do sign up because this post when you register there will be a thing in there and you need to put in my user name which is aquariumlover10.
ok here's pics of my tank wit the sponge on filter
ok I should be able to get the sponge on my filter today will post pics.
thanks, when I get it on my filter I will post pics.
seamster 9 years ago
Nice! Thanks for sharing.
