How to Decarboxylate Cannabis
Intro: How to Decarboxylate Cannabis
If you're wanting to make edibles or tinctures from cannabis, decarboxylation is a crucial step! Decarbing the cannabis you use in medibles and tinctures will make them safer and more effective.
Decarboxylation happens very slowly when cannabis is cured, but we can use an oven to speed up and complete the process. Decarbing your cannabis allows you to convert the THCA found in your dried buds and trim to THC. This will allow your medibles and tinctures to be more potent and take effect more quickly. Decarbing most often occurs when cannabis is smoked, so this process doesn't have an opportunity to occur when making butters, oils and tinctures - you have to do it beforehand!
Beyond turning the THCA found in cannabis to THC, decarboxylation also has one other awesome benefit: lowering the risk of botulism in your medibles. If you don't properly decarb your cannabis, the moisture from it can cause botulism bacteria to grow in your tinctures, butters or oils. And I'm assuming you probably don't want that on top of why you're medicating with cannabis already. ;)
For more information on decarboxylation and also a nice scientific experiment, I recommend reading this article.
In this instructable I'll cover how we choose to decarboxylate cannabis - there are loads of ways to do it, but this is our preferred method.
STEP 1: Tools + Materials
To do this you'll need:
- an oven set to 220 F/105 C
- a baking sheet
- parchment paper
- sugar leaf trim, ground bud, or kief
If using sugar leaves or kief, no other processing is necessary. If you're using full buds, grind them roughly before proceeding. You want things to be broken down well so the cannabis releases all the moisture it's holding.
Today I'm decarboxylating 40 g of Doctor Who trim - we're going to turn it into coconut canna oil.
STEP 2: Prep
Preheat the oven to 220 F / 105 C.
Place a sheet of parchment paper on your baking sheet and spread your cannabis out over it. If you see any large pieces, break them up with your hands.
If you have more cannabis than will fit nicely on one sheet, divide it in half. You just want one fairly thin layer. If you crowd it it will not dry out properly.
STEP 3: Decarboxylate
Place the baking sheet in the oven and let it hang out for 25 minutes.
For well dried trim, kief, and bud this should be long enough. However, if the cannabis you're using is more fresh you may want to take it an additional 25 minutes.
A hygrometer can be useful for double checking to see how much moisture is left, too - just put the cannabis in a closed jar or bag with it.
Once the cannabis is nice and dry, let it sit out on the counter until it's entirely cooled. Now you can use it for whatever medible application you'd like!
162 Comments
MobyNastro 8 years ago
Cant we simply place the leaves+buds directly onto the tray instead of the parchment paper?
I have difficulty sourcing the paper. :(
cameronwilcox98 9 months ago
Curiouscat1 7 years ago
Stef4chase 7 years ago
Cel- 4 years ago
missyhumphrey87 1 year ago
brainiakdumdum 6 years ago
Decarboxylating turns THC-A into THC, which is available to be suspended in whatever medium you are trying for, and the requires heat.
jonesey0423 6 years ago
time will also decarboxylate THCa or CBDa, but it takes time and people usually don't want to wait. Flower that has been harvested for awhile has already lost some of the acid molecules and may not need to be decarboxylated, but if I were using it as medicaine, I would want to make sure to get the most benefit out of it.
LucasW31 7 years ago
Wax paper is all you need or you can use a paper bag but keep an eye on it so it doesn't burn in the oven
bad advice. Wax paper has wax on it and gets into your product.
greenjeen 7 years ago
Nooooo, don't use wax paper! It will leave wax on your material, parchment paper is different, you can order it online, or they carry it at most grocery stores by the foil and wax paper, I buy it at Costco, also available online @ Costco. Very reasonable, it last a long long time, and I use it several times a week.
Cel- 4 years ago
you can generally buy parchment paper anywhere you get wax paper
G-Nasty 7 years ago
You can use the bare tray, foil or whatever you'd like.
CherylP46 7 years ago
Look in the same place you find aluminum foil in the grocery store.
YohonS 2 years ago
brownsarah 7 years ago
EdiblesRule 3 years ago
JackOfHeartsSRL 6 years ago
You decarb in the oven before to convert the THCa to THC. The THCa can't be processed by the body. This doesn't happen unless you get the temperature over 100C, higher than the boiling temp of water or butter.
martin.j.roast 6 years ago
Butter
is an emulsion of fat in water - thus boliling starts at about 100 deg
C. As it is not pure water, but solution of proteins, salts and
hydrocarbons its boiling point will be higher thus 110-120 deg C
