How to Do a Forensic Facial Reconstruction
Intro: How to Do a Forensic Facial Reconstruction
This is a brief overview of how forensic 3-D manual craniofacial reproductions are done. While this instructable will show the process of one case from beginning to end, it is not intended to be a proxy for teaching the knowledge and skills required to perform a credible facial reproduction; that takes years of training. Please vote for this project in the Up contest here! Thanks.
STEP 1: About the Author
I am a doctor of physical and forensic anthropology. Prior to getting my PhD, I was a special effects artist in the film industry for over a decade. I have extensive training in anatomy (both medical and artistic), art and science. These facial reproductions draw on the science behind the morphology (shape) of the face as well as the knowledge of materials and skills developed from working in the effects industry.
STEP 2: The Forensic Workup
Full forensic workup is performed:
Forensic anthropologists use scientific methods to determine the age, sex, stature, ancestry and any abnormalities that are detectable in the bones.
the decedent was estimated to be a white male, between the ages of 45-55
Height: around 5’6”
Died from strangulation
Edentulous (no teeth)
Skull was brought to me for facial reconstruction
Height: around 5’6”
STEP 3:
For this case the skull had to be copied by using slow set alginate to make a mold and cast in a gypsum (plaster-like) material. The cast was not as ideal as working on the actual skull, but it was necessary for the skull to remain in the lab for testing. For this reproduction, the cast worked fine. Due to the decedent having no teeth, you can see the lower jaw takes on a much more severe angle than normal, and the tip of the chin tilts up toward the nose.
STEP 4: Setting the Eyeballs
Eyeballs are then created and set into place in their anatomically accurate position (they are usually positioned at an angle to produce a lifelike effect). Most adult human eyes are about the same size (26mm). This is the eerie part when the skull begins to seem alive!
STEP 5: Estimation of the Nose
This next step has been well studied and documented; there is less guesswork than one would assume. The nose tends to follow very clear guidelines as to the shape and angles of the nose. There are a lot of nose shapes and there is a long list of articles dedicated to this one aspect of the face!
STEP 6: Adding the Nasal Cartilage
In this step a piece of styrene is used to form the "backbone" of the nasal cartilage. The depth markers are also in place but I will explain those in the next step.
STEP 7: Finishing the Nasal Cartilage and Adding Depth Markers
Here the nasal cartilage (the stiff portion of the tip of the nose) is sculpted in and the depth markers are placed at osteometric (specific, measurable points) on the skull. Here again there is extensive literature on the depth of the soft facial tissue at these points; it is based on the age, ancestry and health of the individual.
STEP 8: Adding the Muscles of the Face
Here the individual facial muscles are sculpted in. The placement and thickness of the muscles are determined by the skull morphology (shape) and the tissue depth markers.
STEP 9: Muscles Continued
Here the muscles of the upper face are almost complete
STEP 10: Muscles Finished and Neck Added
Here the muscles of the face and the neck are pretty much done. also, glandular and fatty tissue are added.
STEP 11: Adding the Skin and Ears
In this step the skin layer is added. All the wrinkles and pores are added according to anatomical studies and the estimated age, health and habits of the decedent (such as smoking, alcohol and drug abuse, and sun exposure).
STEP 12: Adding Hair
At this final step any hair, accessories or clothing that were found with the body are added. Photos are taken, often in Black and White so that no information that we do not know for certain is conveyed to the public (such as eye, hair or skin color). And hopefully someone recognizes the individual so that an identification can be made. Please vote for this project in the Up contest here! Thanks.
One final note, this case did end in an identification, but I cannot add any details of the case or pictures of the individual for obvious reasons, so please don't ask.
67 Comments
Brianaala 11 years ago
Thanks again for your interest!
RobertK62 6 years ago
Hello Brianaala. Hopefully a quick question. On average, how long does it take from the time the skull is brought to you until completion? Assuming there is some sift tissue to work with (even heavily burned)?
PatB143 6 years ago
This was the question I was looking for the answer to, and I didn't see it. Need it for a mystery book I'm working on. Thanks.
MalikA76 5 years ago
SpencerA18 7 years ago
How much of this is artistic interpretation. It seems that if there is a scientifically proven process that it could be automated entirely in the computer before 3d printing. Are there any automation tools out there for determining all the measurements from a skull geometry or inversely deriving a skull shape from surface topology.
mishacollins 7 years ago
lol die bitchesss
Rose_way 8 years ago
rice-nd-music 9 years ago
Hi, I'm doing my Undergraduate honors thesis on forensic facial reconstruction, and was wondering if I could contact you and ask you some questions about your job and the field in general.
TrollFaceTheMan 10 years ago
Very Cool and Informative, Nice Job and Thanks.
jrsfo 11 years ago
Absolutely, that would be a fun project! I would suspect that if it is a plastic skull (one cast from a mold of a real skull) and relatively new, you will find that it is a young female of East Indian descent. You could start with a google search on Caucasian depth measurements and go from there!
jrsfo 11 years ago
xenobiologista 11 years ago
yes a little of both; in the case above I was referring to a particular skull that pops up a lot (a really good cast was made and it has been produced a lot). Also, the culture in India is such that they were selling a lot of bones for a while, as a result most of the specimens come from there.
Sequimania 11 years ago
I find this type of science-art hybrid fascinating. (Er, yes I do have a degree in each discipline.)
Regarding the angle of the chin - does it increase when an individual loses their teeth? Or in this case was that apparent due to the lack of any dental remains (? fragments?). It seems as thought the bone surrounding the roots would show changes after tooth loss?
Thanks! Any answers are appreciated.
Euphrosyne 11 years ago
