How to Do a Lapisneta
Intro: How to Do a Lapisneta
I am going to show you, quickly, how to do a Lapisneta.
Lapisneta is a half pen and half pencil gadget. It´s very easy to make and everybody can do this at home.
The reasons for lapisneta use are:
• Nobody will take your pen or pencil away, intentionally or not, because you will be the only one that have one of this.
• It´s very easy to carry.
• You will look like an authentic fulltime DIYselfer.
• And it´s a pen and a pencil…at the same time! You don´t need any more search for a pen or a pencil, because now they are in the same place, and thus you don´t will lose time… and time is money!!
STEP 1: What You Will Need:
A pen (preferably spent by half), a small pencil and a little bit of adhesive plaster (or other kind of adhesive tape)
STEP 2:
To occupy less space, you may to saw off the pen a little above the ink tube, and also cut the ink tube.
Remember to mark your best size with your pencil.
STEP 3: Now, a Dowel
Using a knife, roll the pencil along it to mark and to delimit the place to chop (it’s very important to do this step, because we need to chop and trim carefully, avoiding an irregular and asymmetric surface). I recommend making a dowel neither so large nor so small. It may crash if so large, and don’t fix well if so small
STEP 4: Chopp and Trim
STEP 5:
The dowel must be smaller than the pen hole, so as you go chopping, it’s good to measure the pencil dowel in the pen hole. Keep trying until it fix relatively firm. (now it’s a protolapisneta!).
STEP 6: Almost There!...
With an adhesive plaster, roll up the protolapisneta, with 3 or 4 turns. It’s important to roll very, very tight! Always try to hold it from the pen side.
4 Comments
arenalestorres 10 years ago
In time, here is an updated with superglue! ...it works fine!
Thank you, MrOddjob
l8nite 10 years ago
l8nite 10 years ago
MrOddjob 10 years ago
