How to Find a Break in an Invisible Dog Fence
Intro: How to Find a Break in an Invisible Dog Fence
Recently I went into my garage to find the invisible dog fence transmitter beeping. After calling the company I was informed that this alarm meant there was a break in the fence, and that I should have them come out as soon as possible - because my dog would surely figure this out in a few days. And hey, for only $100 an hour, they would be happy to help! Long story short, they tried for an hour then told me the yard was too overgrown (half the yard is wooded) and they would have to come back in the fall when everything died back (2 months away). This made me swear that I would do it myself - but after digging up over 100 feet of wire and driving myself crazy for a few days, I had not found the break. Then I found this strategy on the internet (link) that cost me under $20 and worked like a charm. Hopefully this makes it clear for everyone else and saves you some money and frustration. Good luck!
STEP 1: Verify the Break
First thing to do is make sure that you do indeed have a break. There are a few ways to do this. On my unit, two wires run from the transmitter to the perimeter fence. Disconnect these wires from the transmitter and put the ends of a paper clip or small piece of wire into the jacks where the wires had been connected. If the alarm is silenced, the transmitter is working properly and you have a break. Another way to verify that there is a break is to use an ohmmeter and check the resistance on the disconnected wires. If there is no resistance the wires are continuous and there is not a break, meaning you may have a problem with the transmitter itself.
STEP 2: Materials
To start, you'll need to round up a handheld AM radio and a RF choke (Radioshack part number 273-102).
STEP 3: Connect the Choke
Take the two wires that you disconnected from the transmitter and connect them to the leads of the RF choke. Then insert the leads of the choke into the jacks on the transmitter where the wires were originally connected. As I understand it, this allows the transmitter to continue sending a signal to the fence even though it is broken.
STEP 4: Tune In
The fence emits a radio signal that is picked up by a reciever on your dog's collar when it gets in range, causing a warning signal or an electric shock. You should be able to detect this signal in the lower AM range. The signal of my fence was roughly 600 kHz. When tuned to the right frequency, you will hear the signal as you pass the radio over the ground. It may be necessary to turn up the intensity of the signal at the tranmitter, although I didn't have to (there should be a numbered dial somewhere on the transmitter, just remember to turn it back down later so you don't fry fido!)
STEP 5: Find the Break
STEP 6: Dig It
When you've located the area where you suspect the break to be you'll need to expose the wire. I used a 3-pronged hand tiller and dragged it perpendicular to the wire, the invisible fence guys used a pick axe. Use whatever you like but be careful that you don't cut or knick the wire in the process.
STEP 7: Check the Break
Once you've found a break, use the radio to check that you have a strong signal on both lines. I actually had two breaks but didn't know it until I found the first break and realized that one of the ends did not have a signal. I continued to dig in the direction of the dead line and found a second break a few feet away. If you have a strong signal on both ends connect them with a piece of wire, disconnect the choke and reconnect the wires from the fence into the transmitter. If the alarm goes off, congratulations, you've found your break!
STEP 8: Mending the Break
The final step is connecting the broken ends in a way that is weatherproof and secure. I bought these connectors from the local hardware store, time will tell if they are the best ones or not but you want something that is waterproof and suitable for the temperature range in your climate. This type of connector is filled with silicone to seal the twisted wires. Once you're sure the fence is operating correctly, bury the mended wires and you're done! Good luck!
158 Comments
gtyler1961 1 year ago
donens 3 years ago
Jebulous 2 years ago
esteffen 3 years ago
countrygrl24 4 years ago
gcmillerj 10 years ago
A friend of mine and myself are both very knowledgable in electronics and radio systems. We spent quite an amount of time trying to use the above procedure to find the break in my PetSafe system. It wasn't that we just couldn't find the break, the procedure just didn't work.
I started doing a lot more research on the Internet and believe that the PetSafe device uses a more complex system that does a better job, but requires specialized equipment to troubleshoot it.
I am checking into that now. I'll let you know what I find out.
DavidU65 5 years ago
New (April 2019) PetSafe unit Model 300-1051. RadioShack RF Choke 100 microhenries. No joy on any of the A/B/C frequencies on the unit. Experimented with a known-good 20-foot loop of wire in parallel with the choke, AM radio antenna an inch away. No frequency found on AM radio between 560 -> TOP-LIMIT where level of static had any correlation to proximity to wire loop. No pulsing/beeping nature of static anywhere at all. Perhaps I'm cursed with a local radio station that swamps it, but seems odd that it would swamp all 3 freq. options from the A/B/C selector switch on the uniit.
huges84 8 years ago
borodelostoldos 10 years ago
Thanks!!
dmaxwell4 5 years ago
AngelaV40 5 years ago
Step number one just saved me a fortune. I was given a quote to reinstall my whole fence because it is older. I found the problem and the fence is working with no digging required. Thanks!
CatherineH84 6 years ago
I can't thank you enough! We just got a second dog and had a break somewhere on our 1/2 acre we have wired - after many downed limbs this spring, we were seriously doubtful of finding the break....so happy we came across this website. Ordered the parts on Amazon for less than $20 and found the break in a very unlikely spot!
PJMc2 10 years ago
Before you go through all this, I'd suggest that you double check your transmitter. I have the Radio Fence Pet Safe RF-1010. It started beeping so I was certain that it was a line break. I did all these steps, and spent hours, then simply turned the dial all the way clockwise to 10. For some reason, the sensitivity changed from around 2 to 7.5 on the unit! Below 3, beeping, above 4 it went away! It now works like it did before, and it looks like the problem is solved.
L8apex 6 years ago
d1no 6 years ago
Does anyone know the difference between the old and new pet safe systems? (The frequency maybe?) I have an older system. It looks like the one in this article. Pet safe is telling me I need a new system if I want new collars. The old collars are not available.
MamaLoca 7 years ago
Thanks for this Instructable. We found the break and our Beagle is happy to be off the chain.
cgosh 7 years ago
Your local AM radio stations may or may not be close on the dial to the frequency the dog fence broadcasts. A cheap-o AM radio might work better than an expensive model (less sensitivity and less adjacent-channel rejection on the cheap model). YMMV so try different radios.
FWIW, the purpose of a choke is to pass DC current (measured in volts, so the fence system thinks a wire is shorted across the terminals) while blocking any AC (the noisy part that shows up in the radio is NOT shorted out, so it continues down the buried wire). You can make one -- it's just a coil of wire. Google it. Perhaps this system uses a constant DC voltage to test for continuity through the buried wire, and an AC signal (the "noise" you hear) to trigger the dog collar. A break would cause the beep that tells you the wire is broken (DC missing in the wire loop) and so you fool the system with the choke so you can test with the AM radio. Simply shorting the wire could diminish the signal to the radio, but I'd obviously try it and see if it's loud enough to do the job.
KenB91 7 years ago
FORGET THE CHOKE. You don't need it. Just use a piece of wire in place of the choke and follow the instructions as provided. I plugged both a short piece of wire and the broken perimeter wires into the control box and it sent the 600 mHz frequency out the lines that was detectable by an AM radio tuned to 600. I have just over 1/2 acre inside my perimeter. Maybe the choke is useful for longer runs, but I did not need it.
DaveH130 7 years ago
With the RF choke the collar still works. I taped the prongs and used it.
