How to Fix the IPhone 5 Back Housing
Intro: How to Fix the IPhone 5 Back Housing
This is a step by step instructional tutorial on fixing, teardown, and repair of an Apple iPhone5.
STEP 1: Step by Step Video on Repairing Your Apple IPhone 5 LCD Screen
This is a video demonstrates the repair of an iPhone 5 in detail. This video will guide you step by step on dismantling and assembling, you can find all tools and parts at https://flashtechllc.com/ Want to know more about screen repair? Subscribe to our YouTube channel for repair videos on other models.
If you have specific question on repairs, Just message us at https://www.facebook.com/flashtechllc
You can purchase your iPhone 5 screen replacement assembly here:https://flashtechllc.com/62-iphone-5
STEP 2: ISclack Opening Procedure
•The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5 that we recommend for anyone doing more than one repair. If you aren’t using the iSclack, skip to step 4
•Close the handle on the iSclack, opening the suction-cup jaws
•Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge
•The top suction cup should rest just above the home button
•Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
STEP 3:
• Peel the two suction cups off your iPhone.Skip the next three steps and continue on step 7.Press a suction cup onto the screen, just above the home button.Be sure the cup is completely on the screen to get a tight seal.If you’re opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
STEP 4:
• Make sure the suction cup is firmly attached to the front panel assembly
• While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case
• Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices
• With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup
• There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly
• Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
STEP 5:
• Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone
• Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case
• Lift the front panel assembly slowly up to about 90 degrees from the rear case.
STEP 6:
• Remove the following screws securing the front panel assembly cable bracket to the logic board:
•Two 1.2 mm Phillips screws
• One 1.6 mm Phillips screw
• This screw tends to not be attracted to a magnetized screwdriver
• Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
STEP 7:
• Remove the front panel assembly cable bracket from the logic board
• User note: To ensure correct installation, make sure you clip the small hooks of the bracket under and then lower towards the outside of the phone.
STEP 8:
• Use a plastic opening tool to disconnect the three front panel assembly cables:
• Front-facing camera and sensor cable
• LCD cable
• Digitizer cable
• When reassembling your phone, The LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
STEP 9:
• Remove the front panel assembly from the rear case
STEP 10:
• Remove two screws securing the front-facing camera bracket to the display assembly
• One 4.1 mm Phillips screw
• One 2.2 mm Phillips screw
STEP 11:
• Remove the earpiece speaker bracket from the display assembly
STEP 12:
• Remove the earpiece speaker from the iPhone
STEP 13: Front-Facing Camera and Sensor Cable
• Starting under the earpiece speaker contacts, use a plastic opening tool or the tip of a spudger to pry the front facing camera cable out of the display assembly
STEP 14:
• Remove the front-facing camera and rear microphone assembly
• If you are installing a new part, your new part may have two tabs with holes in it used for manufacturing purposes. These tabs can be cut off with scissors.
STEP 15: Home Button Ribbon Cable
• Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly
STEP 16:
• Use a plastic opening tool to pry the edge of the home button ribbon cable up from the display assembly
• Start on the right, at the area of the ribbon cable between the gold contact points, and work to the left
• Going left to right may rip your ribbon cable as the contacts are well adhered to the front panel
• Prying directly at one one gold contact point or the other may break its soldering and pop it off the ribbon cable
• If you have trouble sliding the plastic opening tool under the contact points, flip the tool over and gently push against the right side of the contacts to loosen the adhesive, then try again.
STEP 17: Display Assembly
• Use a plastic opening tool to pry the home button up from the display assembly
STEP 18:
• Remove the home button from the display assembly
STEP 19:
• Remove two 1.2 mm Phillips screws from each side of the LCD frame (four total)
STEP 20:
• Remove the two screws securing the LCD shield plate to the display assembly:
• One 1.4 mm Phillips screw
• One 2.6 mm Phillips screw
STEP 21:
• Remove the LCD shield plate from the display assembly
STEP 22:
• The bare display assembly remains
• For reassembly, make sure to transfer over the LCD shield, home button, front facing camera assembly, front facing camera lens bezel and earpiece speaker to your new part
• Make sure to remove the protective cover from your new display assembly.
2 Comments
tomatoskins 9 years ago
I actually replaced the screen on my girlfriends phone just a few days ago. Super simple, thanks for sharing!
FlashTech 9 years ago
Tomatorskins,
Thanks, Keep watching we will have many more "How to" videos coming up on, Samsung, LG, HTC, iPad, and iPods.
