How to Fix Your Swamp Cooler ("Overclock" It 50%)
Intro: How to Fix Your Swamp Cooler ("Overclock" It 50%)
Swamp coolers work ok until it reaches 94 degrees. At that point, they stop cooling as well, because the pump can not get enough water on the pads to keep them wet. So by increasing the amount of water going to the pads by 50% the unit cools the house down faster, and the pads don't dry out.
STEP 1: Replace the Blue Pads With Good Old Aspen
The blue sponge pads do not really absorb the water very well and do not cool well at all. So pitch them and replace them with the low tech, sustainable aspen pads. the aspen wood actually absorbes water in additon to creating a curtain of water which makes the swamper cool better. It does get messy at the end of the year but it is worth it. These pads are also cheaper.
STEP 2: Materials
you will need the following: (I purchased everything at Home Depot, but any decent hardware store should stock it) A pump, a supply tube, a distribution array ("spider") a pump basket, a basket filter bag, a grounded 3 prong splitter (not pictured) 7" and 14" zip ties... (10 of each should do) a pair of dykes, a utility knife, a radio or cell phone to have someone turn on and off the pump for you and about 2 gallons of water- to drink while you are cooking on top of the roof because you didn't get started until 1:00 pm in the afternoon.
STEP 3: Shut Down the Power and Lock Out the Power
ok. Go to the power switch and turn off the swamper. Then take some duct tape and tape it off. Then put a little sign that says not to turn on the power. (if someone turns on the fan motor while you are in there you will get hurt.) Also, you can unplug the fan motor up in the swamper for extra safety.
OK.. notice that there are 8 tubes on the distribution assembly, 2 on each side. We are going to add 1 tube to each side taking the total tubes to 12, our 50% overclock.
STEP 4: Arrange the Secondary Distribution Array
Now take the spider and put 4 of the 8 tubes in it so that they form a cross. Then Put it up under the existing one and loosly zip tie it into place ( you are going to cut it down in a minute). Next you need to cut the distribution tubes to length such that they will empty out into the trough. (I had to offset the center of the second spider slightly so each tube is a different length) Measure the distance you need then pull the tube out of the spider and cut it down. then re- insert it. Repeat this on all 4 sides.
STEP 5: Remove Spider, Glue It Up , Install It Again
Cut the zip tie that is holding the spider in place and pull the spider out (keeping track of the orientation) then use the glue that comes with the spider to quickly glue each piece in. Then you will need to glue the plugs in for the other 4 holes that you aren't using. Make sure the tubes are pointing down, because you don't get 2 chances at gluing since it welds the plastic.
Now re-install the spider. I used two zip ties to hold it to the original one. I went around it in an x pattern. You may have better, and cleaner ways to do this but the reality is that the roof was about 105 degrees so zip ties seemed great at the time
STEP 6: Install the Pump and Supply Line and the Power Connection
Now put the basket filter on the basket, the basket in the water and the pump in the basket. Take the supply line and run it up to the spider alongside the original supply line. (the tubing I purchased tended to kink so I tried to zip tie it every so often to the original to keep smooth curves.) Cut the tubing to length and fit it onto the spider.
Unplug the pump power from the connection and pull that connection out of its mounting slot. I got a grounding splitter to plug both pumps into the power source. (they are now both controlled by the main switch.) I zip tied it to the mounting area making sure that the cords are attched with zip ties and the whole thing is out of the way of the fan, fan belt and the water. You dont want something migrating into one of those areas.
STEP 7: Turn on the Pumps for a Test
Now call down and have somone turn on the pumps only and you can verify that you are getting the water comming out of the pump and that the spider is filling the troughs and there are no leaks. Also check that the pads are aligned correctly and you are getting good distribution of the water. Let the pads soak for about 5 minutes and then let it rip.
STEP 8: Improvements and Such
I would be interested in ideas to improve the cooling ability of this project.
My business parnter said that the second pump should only come on when it is over 95 degrees outside (to save electricity) and that I should install a second switch for the second pump.. But I don't want to do the wiring.
so, possibly a wireless switch in the swamper with the other switch downstairs. It would be really cool if you could just get the second pump to kick in when necessary, but that is beyond my techability.
Other ideas might involve adding a unit for spraying the inside or outside of the pads with a sprinkler head. to get better distribution of the water on the pads.
Anyway, hope it works for you .
135 Comments
Bcron 1 year ago
If you run too much water to the pads it will run on the fins and rust them and depending on your water, add calcium on the fins.
This has been my experience with the 50 years of running swamp coolers. Including here in the southern Nevada area where it gets 120*.
Swamp coolers here work great except when the humidity gets above 40%.
k8e 1 year ago
Iron_Willed_ 2 years ago
subwayco1 2 years ago
Philwhipple 3 years ago
heroay 7 years ago
Please pass on this information. My mailman recommended I add a floating (it does) IVORY soap bar to my swamp cooler. I did, then I disconnected the second drain pump (worked every 8 or 12 hrs), and let the system run on its own. NO drain at all from then on.
The Aspen pads were clean of crust at the end of the season; the usual heavy calcium scale on the pads and the pan was absent (only the accumulated dust on the bottom); and cleaning the unit for winter was a charm. The soap, however, was an ugly looking thing, swollen out of proportion, with black, gray, and rust colored spots, and would disintegrate after letting it dry outside the pan. All the damaging chemicals or minerals in water are acid, the soap is alkaline. They attract each other neatly, and the water, pads, and unit remain clean from all those chemicals and minerals.
Now, these pads were already 3 years old (!) before the Ivory soap, and I maintained these before without scale by adding a gallon of white vinegar to the tank at the start of the season, and a half a gallon again every two months. The drain pump would empty all the calcium filthy water every 8 or 12 hours, and start all over again. But with the addition of the Ivory soap (alkaline, and there are several other brands) I stopped adding vinegar to the tank. Besides, these pads were ready to be discarded after the first 3 months of use, but the vinegar cleaned them out and the entire unit off the calcium deposits after a 4 hour run, then continued using the same pads for the following 3 years. Until Ivory soap.
I had to discard the pads after another year because they developed a black fungus-like deposit on the outside, sunny side of the pads. Rotten wood? Fungus? Just replaced them; they paid for themselves many many times over. And YES, both the vinegar or the Ivory soap will keep the air smelling CLEAN. Both kill the fungi that grows in the internal 'swamp' that releases the sewer pipe smell gas into the house.
trecenters 4 years ago
heroayINS 4 years ago
would be the tenuous scent from it, but inside the house there is no
smell of any kind. Up close, though, the eventually ugly looking soap
does have a peculiar smell due to all the chemicals and bacteria
locked up into it. By now I don’t let it float around since in one
season last year it roamed right under the valve float and locked the
water off three times. I am keeping the soap inside a plastic cage
for water pumps; same cleansing and deodorizing of the tank water,
but no water lock up. And the gallon vinegar, only at the beginning
of the season, to remove any possible leftover scale from the
previous year. BTW, I modified my cooler with a homemade Master Cool
equivalent and a 12 inch thick synthetic pad. The pad stays clean as
new.
JeffB346 4 years ago
holbell 5 years ago
TomR194 5 years ago
vatosupreme 5 years ago
I would try the switch first. It's cheaper :) If that doesn't work, proceed to getting a new motor, make sure it has 2 speeds ( I think pretty much all of them are 2 speed though)
Embryinc 5 years ago
pscott2 5 years ago
https://www.amazon.com/Temperature-Controller-Ther...
Well within your techability ;)
KaseB 7 years ago
Now you can open up these slots a bit more and let more water through but if the bottom of your pads stay wet already then this isn't going to help much.
In my opinion your best bet is to check the temperature of the incoming air right at the cooler vent and if the further reaches of your house are significantly hotter than this, say 10-15 degrees then you need more air movement.
If so make sure you have a window partially open in the room/rooms you want to be cooler. I'm surprised how often I have to explain this to my tenants. An evaporative cool is not a closed loop system like an AC unit. You gotta let the hot air a way to escape to let cooler air in.
Now if you are already doing that and you still need more air movement your best bet is to change out the little pulley on the motor to a larger size. This will cause the squirrel cage to spin faster and move more air. If you cannot get the pulley off you can always buy a new motor with a little more hp and put the new pulley on that. Just make sure to check your temperatures to see if it is going to be worth the effort.
Now I'm sure you are asking yourself why you should believe me and not the guy who wrote the article. I service 300+ evaporative coolers on a yearly basis and I have a lot of experience fixing/replacing them.
A final note don't expect an evaporative cooler to be more than 20 to 25 degrees cooler than the outside air temperature. If you are already in that range and you want to be cooler your best bet is to go with an AC unit. This is the reason why you don't see many evaporative coolers in places like Phoenix Arizona, it's just too hot for em. If you have any questions, feel free to message me.
Itlleprcn 6 years ago
So whenever I turn on my swamp cooler sand and debris blow through the front grill. I live in the high desert and was wondering if it's possible to take off the face plate of the cooler (It's coming in through the window) and put in a thin filter of some sort?
Thanks in advance!
Melissa
KaseB 6 years ago
BryantI 7 years ago
Hello have you ever had a condition where the blower is sucking water out of the pads as its going down the face of them which in turn the water spins around the blower for a little bit but eventually spits out into the house... i have the blue pads and im wondering if it has to do with them not absorbing the water and its just going on the face of them which allows the fan/blower to pull the water. the other thing i thought about was possibly the blower is spinning too fast? your help is appreciated
