Introduction: How to Get an Uninterrupted Power Supply of 5.3v From a Mobile Phone Charger A.k.a How to Make a Adapter of 5.3v?
If you are having a mobile phone charger you can easily make a adapter supplying a low voltage.I am having a NOKIA AC-2N charger and it's output is approximately around 5.3v.You can use any mobile phone charger but first see it's output voltage.At first, plug in the charger.
Step 1: Step 1
Attach a paper clip over the socket as shown.Connect a wire.This is your negative terminal supplying 5.3v.
Step 2: Step 2
Insert a pin inside the socket ,this makes your positive terminal. Be careful about inserting the pin make it as soft as you can.Run any device for testing your new adapter.
Step 3: Enjoy..........
Enjoy with your new adapter but avoid short-circuiting the wires for it will reduce the charger's life.
Hack It! Challenge
Pocket-Sized Contest
6 Comments
7 years ago on Introduction
How is it uninterrupted?
10 years ago on Introduction
could always just buy a female connector (or hack your old phone for free) connect to the needy..that's what I do.
But that's my mom's charger, so I decided to take the power without doing any 'hack' thing!
Yeah female connectors are always helpful.Currently, I am running a small pocket fan that I made of a d.c. motor with a female connector!
Why not just cut the wire and remove some of the insulation?
bcoz in some chargers da wire is separated by a thin nylon strip n wth dis u dont hve to 'destroy' ur charger up!!!!!!!!!!!!!!!
