Introduction: How to Get Rid of a Ring Around the Sink Drain Easily With Household Objects
I've tried this method several times, it always works.
Step 1: Gather Tools
All you need is an old toothbrush and some hydrogen peroxide.
Step 2: Pour It In
Make sure the drain is closed and pour enough hydrogen peroxide to cover the drain.
Step 3: Let It Soak
You will see it start to foam up, let it sit there for about 3 minutes.
Step 4: Scrub
After about 3 minutes, take your toothbrush and scrub around the drain.
Step 5: Drain
Drain it and run the water.
Step 6: Ta-da!
You're done!
3 Comments
7 years ago
Peroxide is non toxic & doesn't smell like vinegar. I use this technique. It is quick!
8 years ago on Introduction
I use citric acid as it is non-toxic, much safer and does not smell like vinegar. It is quite useful for removing deposit from kettle as well.
Here's a different method that works for me. Wet toothbrush + baking soda. Scrub.
