How to Get Rid of Pimples
Intro: How to Get Rid of Pimples
This is going over how to get rid of pimples, with simple supplies and no brand named treating medicine. This is very effective. I do not know if this will work on acne, becuase I have been using this and never have had real acne. If you like this rate it.
WHEN DOING this try not to touch your face very much.
STEP 1: Supplies
Get rubbing alcohol, some bandaids, and a Q-tip.
STEP 2: Apply on Face
Apply the rubbing alcohol on your pimples. Just dip the Q-tip in the rubbing alcohol and apply.
Note that rubbing alcohol is very strong, not liable for anything that can happen.
STEP 3: Apply on the Bandaid
Get another Q-tip and soak the end. Dab it on the white part of the bandaid.
STEP 4: Wear the Bandaid Over the Pimple
Now just put on the bandaid, making sure that the white space (middle part of band aid) is on the pimple. I put this on right before I go to bed so, and found this to be the best method.
STEP 5: Air It Out
Now just take it off and wash your face.
74 Comments
winneremerald12 5 years ago
Not sure why I’m here...don’t even have acne. I get a pimple now and then, but I just pop it, wash it, and the next day it’s gone.
joey2542667 15 years ago
And disinfect after so it won’t blow up again. ;)
aalbarran2 10 years ago
*wince*
kennyhemens 8 years ago
Are you sure?
B.S SystemS 7 years ago
Doctor
exhibits high-quality way to hit A Pimple without off-putting your pores and
skin
http://www.leaktattle.com/doctor-exhibits-high-quality-way-hit-pimple-without-off-putting-pores-skin/
shezay 7 years ago
Oxygen facial is one of the latest techniques to get rid of pimples, here it is http://www.laserskincare.ae/treatments/acne-treatment/
CrazyL3 7 years ago
Toothpaste is instant sure an acne!!
nnamoi 8 years ago
In order for you to get rid of acne forever,
1. You must learn what the cause of your acne is and how to control it.
2. The right and effective acne treatment means a treatment not only remove acne from the face but it also stops it from coming again.
This programme covers both these methods perfectly. I had tried a lot of methods to rid myself of my crippling acne. This program worked. My acne had cleared up and very quickly, I might add. My skin is now remarkably clear. Not a day goes by where I don't thank the lord that I found this powerful solution. It really works, I highly recommend you to check it out. www.homeremediesforacneproblem.com
JeraldR 8 years ago
JeraldR 8 years ago
JeraldR 8 years ago
Step 1=Wash your hands to remove dirt on your hands.
Step 2= Wash your face with soap.
Step 3=Dont wipe your face, wait for the water to dry on your face.
Step 4=When the water on your face dries up put a facial cleanser.
Step 5=dont rub your face or scratch your face. Pimples might spread on yor face.
Step 6=Do it when you wake up and before you sleep.
Gogirl8 9 years ago
emmagaff12 9 years ago
chandrasiri.wickramaarachchi.5 9 years ago
I am following the programme "Acne No More" by Medical Researcher and Nutritionist Mike Walden and in it, he covers both these methods perfectly. I had tried a lot of methods to rid myself of my crippling acne. This program worked. My acne had cleared up and very quickly, I might add. My skin is now remarkably clear. Not a day goes by where I don't thank the lord that I found this powerful solution. It really works, I highly recommend you to check it out. www.getridofacne.best-online-solution.com
kstak11 9 years ago
I used to do rubbing alcohol but it never cleans my forehead. I have some acne on my forehead on my hair line. I just use acne pads and they clean my cheeks, nose, forehead and hair line. Sometimes I have to scrub my face, but that stings when I go over it with the acne pads.
William Beckett 9 years ago
I really like your blog!Especially the way you have used to explain the treatment of avoiding pimples with the help of pictures!
I really appreciate your effort!
My sister is facing problem of acne and she is following this site Http://helpmyacne.net
I am for sure going to suggest this site to her
Thanx for your help !
sathanere 10 years ago
This article is really amazing. I have read more about to get rid of
pimples problem. I have another article which is the best collection of
tips according my knowledge. I think this will also be helpful for
you.Click the link below to redirect the page. I have given 100% working
tips in this article.
http://sumitathanere.hubpages.com/hub/Get-ride-on-pimples-remove-pimples-erase-pimples-acne-homemade-treatment
