How to Get the IWHBYD Skull in Halo 3
33,008
4
16
Introduction: How to Get the IWHBYD Skull in Halo 3
This skull Will change the diologe throughout the game if activated. To activate skulls press x in the campain lobby.
Step 1: What You Need to Know
You must start from the beginning of the level the convandent on anything but easy. Make your way through the level unti you get to the end. After arbiter kills truth , kill all of the flood.. To get the skulls you have to jump throught the holgraphic ring in a order and the skull will appear. From where you entered thats ring 1. Where thruth died that ring 7. If your confused the red ring is ring 4.
Step 2: The Order
Jump throught the rings in this order- 1, 3, 4, 6, 7, 5, 4, 6, 5, 4, 5, 3, 4.
Step 3: All Yours!!!!!!!!!!!
After you jumped through the rings in the right order, the rings will start flashing. Go to the area Where you killed the prophet and the skull will be there. Once activated the dioloug will change during the game.
Be the First to Share
    • Meatless Challenge
      Meatless Challenge
    • Sculpt & Carve Challenge
    • Eggs Challenge
      Eggs Challenge
    16 Comments
    bofthem
    bofthem
    14 years ago
    Hello, and welcome to the Instructables community! This currently does not meet our criteria for an Instructable. A completed Instructable:
    - details a finished project with instruction (not just links to instructions)
    - has clear images that you took of your project (web-found clip-art is not acceptable)
    - uses proper spelling and grammar
    - contains appropriate cautions or safety considerations
    - does not violate someone else's copyright
    - does not violate the Instructables terms of service
    - is typically written about something you are very passionate about and want to share.
    If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
    https://www.instructables.com/id/ELHMNOA69REUF10WM7/
    So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
    bofthem
    bofthem
    14 years ago
    bofthem
    bofthem
    14 years ago on Introduction
    You don't mention what game this is for. It would be good if you took screencaps of this, or had some kind of way to demonstrate the process. Without pictures, this is a little hard to understand.
    dragonsniper
    dragonsniper
    Reply 11 years ago on Introduction
    bofthem you just need to stop commenting when you don't know what you are talking about because he said what game it was for in the title!
    Gamgee
    Gamgee
    Reply 14 years ago on Introduction
    How to get the IWHBYD skull in Halo 3
    tsearmy
    tsearmy
    12 years ago on Introduction
    iv tried 13 different combos can some1 plz tell me if i can touch the rings
    every single time i do the 4654534 and 1346754654534 it doesn't work. can someone tell me what i doing wrong
    cabose201278
    cabose201278
    Reply 13 years ago on Introduction
    make sure you actually through the hoops in order. 1 is closest to the fall pit. 7 is closest to the dead prophet. make sure you kill everything including the flood when they turn against you. start from the beginning of the mission. and make sure the rings flash when you do it. P.S. finish the level.
    cabose201278
    cabose201278
    ha! it works people! make sure you actually jump through the hoops in order 1 is closest to the pit you fall into to end the level and 7 is closest to the prophet. DO THIS AFTER YOU KILL THE FLOOD! make sure that the rings flash when you are done! thanks alot!
    cheesefetty
    cheesefetty
    13 years ago on Step 3
    this blows!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    xxxdominwingxxxx
    xxxdominwingxxxx
    14 years ago on Step 3
    but i got all skulls but that one i jump thougth it in oder and it does not work!!!!!!!!!!!!!!!!!!i get mad when it does not show up
    x z i t
    x z i t
    yo, theres a wayyyyy faster pattern. here da code- 4654534. yeah!
