How to Hot Wax Your Snowboard
8,553
5
5
Introduction: How to Hot Wax Your Snowboard
In this instructable I will show you how to refinish your snowboard by waxing it. Please take it easy on me, this is my first instructable.
Step 1: Gather Up the Materials.
You will need a few things for this....
1. Kerosene
2. Rags
3. Snowboard Wax
4. Iron
5. Plastic Scraper
6. Scotch brite pad
7. Workspace
Step 2: Clean the Board's Base
You can clean the board's base with kerosene, like I did, which seems to work fine, or you can try to track down some base cleaner.
If you are using the kerosene be EXTREMELY careful because it is very flammable! I would suggest using rubber gloves to keep the nasty smell off your hands. First pour a little kerosene on a folded up rag. A little bit goes a long ways so don't use too much. Now just pretty much scrub away with the rag and clean off the board as good as you can.
Once you are done with this part, get a dry rag and wipe over the whole thing to be sure the kerosene is off. I would let the board sit for a while before proceeding to the next step (to ensure there is no kerosene left on the board).
Step 3: Melt the Wax Onto the Board.
This is where the fun starts. A little tip I heard was that your bindings may make a small indentation on your board, so loosen the screws, you don't have to take them clear off, but loosen them enough to take off the indentations... Start off by setting your iron to the "cotton" setting. If when you start ironing the wax, the iron starts to smoke, turn the temperature down (use an iron that can be specifically for waxing your board as it will be ruined for everything else). While it is heating up, set up your work bench. I used two tool boxes set apart far enough so that my bindings could fit between them. Also I suggest putting a sheet or newspaper on top of table to stop drips from getting on the table. Once it gets hot, hold the iron above your board a few inches, not too high though or else the hot wax will splatter everywhere. Go in a zig zag pattern over the whole board, except the very ends. Try to focus getting the most wax on the edges because that is probably where you need it the most. It is o.k. to use a little too much wax. If you use too much it will require more scraping but it is better than having to rewax your whole board because you put too little.
Step 4: Smooth the Wax
Now that you have your wax dripped on your board, you will need to smooth it over the whole board. Keep your iron on the same setting and begin to iron the wax just as you would a shirt or pants. Be sure to spread the wax over the whole board. You want to go very slowly and apply almost no pressure, and keep the wax smooth, when the wax begins to get clear and glassy then it is beginning to absorb into your base, which is what you want... When you think that it is spread good, let the board cool for 15-20 minutes before proceeding to the next step.
Step 5: Scrape Away!
Now that your board is good and cooled, take the plastic scraper and go at it. This does take some work, you pretty much want to take off all the wax that you can. I would set up a fan to blow the shavings away from you, something I didn't think of until I was done. You will notice that the more you scrape the smoother the board gets, this is what you want. Once you are done scraping take the scotch brite pad and go from nose to tail in long strokes across the whole board. Sorry I don't have more pictures for this step but my camera stopped woking :(
Step 6: Go Shred the Slopes!
Thanks for reading this instructable, if you have any questions just comment and ill try to answer the best I can.
The Instructables Book Contest
Be the First to Share
    • One Board Contest
      One Board Contest
    • New Year, New Skill Student Design Challenge
    • Fix It Speed Challenge
    5 Comments
    Mr Tenacious
    Mr Tenacious
    13 years ago on Introduction
    I presume this would work for ski's! I'm not a board man! Btw great first instructable, I'll have to try it before i head out to the slopes in a months time!
    arhodes18
    arhodes18
    Reply 13 years ago on Introduction
    Yea I'm not too sure about skis (I have never skied before). hey, thanks alot man!
    Mr Tenacious
    Mr Tenacious
    I'll report back soon when i have skied with super speed! Hopefully
    GorillazMiko
    GorillazMiko
    Cool idea. You could probably add this to the Tool Tips contest. But awesome job anyways, this is really cool.
    caledonian
    caledonian
    Never heard of using kerosene, citrus-based base cleaners are the norm, grab a bottle when buying the wax and scraper. Also, for even distribution and coverage of the wax, you can rub it on like a crayon before using the iron the melt it, although sometimes it does help to dribble on some extra by holding the wax to the iron.
