How to Install Google Earth in Linux With One Command
Intro: How to Install Google Earth in Linux With One Command
Installing software in Linux can be tricky sometimes for the beginners. In this instructable, you can install Google Earth with only one command.
STEP 1: Installation
Just go to terminal, paste this command and press enter and it will download and install it for you:
wget http://dl.google.com/earth/client/current/GoogleEarthLinux.bin && chmod +x GoogleEarthLinux.bin && ./GoogleEarthLinux.bin
It can't get any easier.
40 Comments
admin 15 years ago
TSM4245 3 years ago
2021-02-12 18:57:43 Fout 404: Not Found.
longshanks66 7 years ago
This does not work for me.
once downloaded in terminal I'm told to type "googleearth" to launch well when I do this it reports back " unable to find command.
some advice please
regards
christhomas.wakefield 7 years ago
Longshanks66 - The "unable to find command" is a bash (or whatever command-line shell you are using) output. You usually find a compiled binary in the folder that it was compiled in. Sometimes when you download an installer/compiler it makes it's own folders, and you will usually find the compiled binary in THAT folder. IF the installer/compiler binary (unlikely though) copies the output-binary, in this case "googleearth", to /usr/bin/ or some other folder where the system usr has permissions to execute, then running "googleearth" with bash, will look in those folders and then execute it. Apparently not in this case. So. It's likely that you need to precede ./ to the command, thus: ./googleearth OR you could precede the command with /home/Longshanks66/googleearth.
awbowman 7 years ago
Well, that easy one step didn't work for me.
OndraŽ1 7 years ago
That link has Google Earth for GNU/Linux 6.0.3.2197
While the download page leads to 7.1.7.2606-r0 (which can't install in my case)
gnored 7 years ago
Nothing is ever easy in Linus for a newbie. First, chmod is not allowed, so you get an error. Tried running the chmod with its own sudo. No joy. Tried from gui file manager. No joy. So the file is in my home directory, but I'm not allowed to use it. Finally got permissions changed (had to use a+x) on Mint 18. Tried running from terminal and from file manager. System asks what I want to use to "open" it. Sigh ...
AlanP52 8 years ago
Wow that was too easy! I have been struggling for an hour going through all the Google links on how to install "Google earth on Linex" Than came to yous. Fantastic so easy.
Thank you
edsoncosmejr 8 years ago
ed@sarava ~ $ wget http://dl.google.com/earth/client/current/GoogleE... && chmod +x GoogleEarthLinux.bin && ./GoogleEarthLinux.bin
--2015-11-11 17:53:22-- http://dl.google.com/earth/client/current/GoogleE...
Resolving dl.google.com (dl.google.com)... 189.6.76.157, 189.6.76.178, 189.6.76.152, ...
Connecting to dl.google.com (dl.google.com)|189.6.76.157|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 33688483 (32M) [application/octet-stream]
Saving to: ‘GoogleEarthLinux.bin’
100%[======================================>] 33.688.483 128KB/s in 4m 53s
2015-11-11 17:58:16 (112 KB/s) - ‘GoogleEarthLinux.bin’ saved [33688483/33688483]
Verifying archive integrity... All good.
Uncompressing Google Earth for GNU/Linux 6.0.3.2197.............................................................................................
loki_setup: Suspect size value for option option
Installing mimetypes...
Installing desktop menu entries...
Installing desktop icon...
/home/ed/googleearth: 18: exec: ./googleearth-bin: not found
so, what happens???
can i do something?
linux mint
sureshbhavani 8 years ago
Nice tutorial to install Google earth in
Linux , here are the links of Google earth offline Installer download I
got , I think it may help for Windows and Mac users
Download Google earth Offline Installer for windows , Mac , Linux
NickyTelevision 9 years ago
If you don't have yum it fails. It can get easier.
greg0064 9 years ago
It is easier, than using this guide. You just go to
http://www.google.com/earth/download/ge/agree.html, google will check your user agent and automatically give you a link to the package that you need for your OS. If you aren't specifically using a distribution that doesn't have a GUI for installing packages then you will be able to install it with a couple clicks.
sionghua 9 years ago
Hi, how do I remove it after installing it this way? Just deleting the whole folder?
raymond.terry.16 9 years ago
Your command, as shown, worked perfectly with Linux Mint 17 KDE. I appreciate your work and thanks, J.Dwyer / RaymondTerryAuthor.
sanjeev.shahi.779 9 years ago
This version of Google Earth requires LSB 4.0 support which you
do not seem to have.
./setup.sh: 285: [: missing ]
No passwd entry for user 'yum install redhat-lsb'
can anybody suggest the remedy.... please
I am using LINUX BOSS
nerd7473 10 years ago
this will run on the pi as well right?
Sassah122 10 years ago
mclancer 11 years ago
How about explaining what each part of the command means?
I'm thinking of installing Linux (played with and was impressed with a live CD), but
if I have to use the Terminal to install a program... I might as well re-install MS-DOS.
One thought, some are having problems but are using an outdated version of Ubuntu, eg v8.04 and v9.10., Have you ever thought that what you need to run Google Earth is probably part of a more resent version of your OS?
csmith89 12 years ago
$ sudo wget http://dl.google.com/earth/client/current/GoogleEarthLinux.bin && chmod +x GoogleEarthLinux.bin && ./GoogleEarthLinux.bin
[sudo] password:
--2011-09-27 13:57:31-- http://dl.google.com/earth/client/current/GoogleEarthLinux.bin
Resolving dl.google.com... 74.125.153.136
Connecting to dl.google.com|74.125.153.136|:80... connected.
Saving to: `GoogleEarthLinux.bin.2'
100%[======================================>] 33,688,483 37.9K/s in 15m 38s
2011-09-27 14:13:11 (35.1 KB/s) - `GoogleEarthLinux.bin.2' saved [33688483/33688483]
setup.data/setup.xml:1: parser error : Document is empty
setup.data/setup.xml:1: parser error : Start tag expected, '<' not found
Couldn't load 'setup.data/setup.xml'
any ideas please, using (x)ubuntu?
http://www.cyberciti.biz/tips/linux-google-earth.html
