How to Install a SATA CD-ROM Drive?
Intro: How to Install a SATA CD-ROM Drive?
This instructable is teaching you how to install a CD-ROM drive inside a CPU. The steps were easy and clear. And it has high quality images for you easily understand.
STEP 1:
Remove the CPU case.
STEP 2:
Remove the drive bay cover where you put the CR-ROM drive.
STEP 3:
Insert the CD-ROM drive inside the drive bay. Make sure to insert it slowly smoothly, or else it will get stock.
STEP 4:
Fasten the CD-ROM drive with the locking mechanism, to let it steady.
STEP 5:
Connect the SATA power cable to the CD-ROM drive.
STEP 6:
Connect the other end of the SATA power cable to the power supply.
STEP 7:
Connect the SATA data cable to the CD-ROM drive.
STEP 8:
Connect the other end of the SATA data cable to the motherboard.
STEP 9:
After installing the CD-ROM drive and the cables, close the CPU casing.
4 Comments
RubaerS 7 years ago
Can, By any chance, a CD-ROM work WITHOUT the SATA power cable attached to it??? Because suddenly my cd rom stopped working and i saw that it didnt have any sata power cable attached to it( It was working fine and suddenly it stopped..... The CPU casing wasn't opened at all)
richard4872 7 years ago
There are 2 cables. SATA power and SATA data. Both are necessar.
1stA 6 years ago
Would you please send me a link to were I can get these cables please?
rc1889yt 8 years ago
Great, this worked for me. By the way, you need to connect SATA cable on motherboard at lowest GB one, because Drives can't be fast. For example I got 3GB/s and 6GB/s, Hard Drives for 6GB and DVD-ROM Drives for 3GB.
