Datalogging, Timestamp, & Monitor Arduino Data With an Incredible Bash-One-Liner
Intro: Datalogging, Timestamp, & Monitor Arduino Data With an Incredible Bash-One-Liner
The description doesn't fit on one line -- but the code does!
This is a bash one-liner for logging data from the Arduino, and for processing (e.g. timestamping, reacting to sensor readings, etc.) and then redirecting data file.
I have tried this out on Mac Os X, but I'll verify it on the Raspberry Pi right away (as linux can perform nanosecond timestamping).
Code:
cat /dev/cu.usbmodem1421 | awk '{ for (i=0; i<NF; i++) printf $i + system("date +,%s")}'
To use with your arduino:
Just replace the /dev/cu.usbmodem1421 with your arduino's serial port (an easy way to find this is to see which is checked in the Tools -> Port of the Arduino IDE menu)
(If you have both /dev/cu.usbmodem and /dev/tty.usbmodem, then use the /dev/cu.usbmodem one)
Real-Time Monitoring:
Real-time monitoring and command line reactions are simple to add-on, for these examples visit (and please star) the project's github.
4 Comments
Geophysicist 7 years ago
Hi
Thank you so much for this interesting project. But, did you manage to try it on raspberry?
And, if I want to to timestamp sensor readings using GPS synchronized timing do you know how it can be implemented?
Thank you,
Alireza, Geophysicist
jsonius 9 years ago
Do you need an internet connection for the timestamp to work?
jabberwocky1396 9 years ago
Hi Jsonius,
Thanks for the question: no internet connection is required for this method to work. It uses the system's own `date` utility, and can be used completely offline.
-- Greg
scruss 9 years ago
Good effort here - there's a lot to learn and use in Linux!
The command ts (in the Debian/Raspbian/Ubuntu package moreutils) might also do what I think you're trying to do here. Also, if you use gnu awk, it has a strftime function, so you can avoid the system() call and do
gawk '{print strftime("%s ") $0}'
You might also want to try grabserial.
