Introduction: How to Make AMAZING Fire Starters (BoyScout Style)
I have been making fire starters for years now, and they have never proved me wrong. The way I make them is the most economic, and environmentally friendly way out their. (That I know of)
Step 1: Supplies
The items you will need for making these AMAZING fire starters are:
1+ paper egg carton
# any old wax candles or surplus wax
an old pan that you will only be using for this
Kindling (box of sawdust, dryer Lint, etc.)
Large sheet of Wax paper
Scissors ( only if using 2.5 Dozen egg carton)
Source of Heat ( Stove top, hot plate, etc.)
[Wax can be a lot cheaper than people think. I got about 10 pounds of wax for $8.50! Just check out your local second-hand store or a garage sale. I went to value world for mine]
[I got the sawdust from a local sawmill for FREE!]
Step 2: Prep.
Before you start anything else you should put the wax in your pan and set the heat on medium-high. Don't leave it on high for too long or the wax will begin to boil and you don't want that. Once the wax begins to melt you should turn the heat on to low so it gives you more time. After you have the wax melting you should start to stuff your egg carton. If it is a 2.5 dozen then cut it in Half. This will make it easier on you later.start to stuff the tray. If using only lint then you must pack it tight. If using sawdust pack it moderately tight.
Step 3: The Birth of a Fire Starter!
Make sure your egg carton is on top of the wax paper.
After the wax is completely melted, and the tray is stuffed full of your kindling (lint/sawdust), you can begin to pour out the wax SLOWLY into the egg carton. Be careful the wax is very HOT!. The egg carton and Kindling may begin to sizzle depending on how hot you let your wax get. don't worry its normal.the wax paper is under the tray so if any wax leaks out the bottom of the tray. If it does just let it cool there and you can break it off of the egg carton once wax hardens. It comes of the wax paper very easily. Just through in your pan for next time. If you want you can top with lint like i did to act as a wick. If doing this add after wax, and press firmly so it sticks to wax. Don't wait till wax hardens to add lint.
Step 4: Build a Fire!
You can taking these on hiking trips or use them at your home. They work very well. Just lite any exposed egg carton or lint. I usually start off with one and some small sticks but the more you use the easier to start the fire. Comment me!! All the fire in the last picture is from ONE fire starter.
115 Comments
2 years ago
cool!
3 years ago
I make these with wood shavings and wax, and the wax needs to be as hot as the double boiler can get it. Otherwise, the wax cools before it soaks to the bottom, leaving some wood and egg carton dry. Then they fall apart later on in the container. You want it to soak through the egg carton.
5 years ago on Step 1
Also, for you school teachers out there, you can save those pencil shavings from the pencil sharpener, after about a week, I got enough shavings to use
5 years ago
Far easier and cheaper than this is a VERY simple trick that anyone can do for a few cents each. Go to most any Dollar Store and get a 50-ft length of 1/4-inch (6-mm) diameter COTTON (MUST be Cotton ONLY) clothesline. Now, at home, cut it into 1-inch long segments until you have the desired quantity. Warm a small amount (2-3 tablespoons) of Vaseline (or other petroleum jelly) until it melts (over a safe, non-flammable hotplate or surface). Now, using a steel fork, slowly drop the cut cord pieces into the pan, gently stir and press on them until they soak up the Petroleum Jelly (it should be like warm cooking oil in fluid nature when warm), then with the fork, carefully pull them out and place on a clean pizza pan or cookie sheet to cool. When cool, they will congeal until like 'greasy bacon'. Place them in any Polyethylene container (plastic, like a vaseline jar or small butter tub), and use them as you need. Pull one out at a time, light it with a lighter and quickly place into your kindling to start your fire. They will burn 6-7 minutes robustly, and with a good ferroceramic stick, they will also relatively easily light as well. Super-easy to make, easy and cheap to make a lot of them, and safe to store (ziplock bag will work, and a one-quart bag can hold hundreds).
6 years ago
I like my fero rod and striker. I like using cotton balls but they burn up too quick if your tinder is damp or wet so I put a bit of petroleum jelly in them so they burn several minutes and store several dozen in a ziplock baggy. I also use jute twine soaked in bee's wax. The trick in lighting both these with a spark is separating the fibers into a fluff and they will light easily with a couple strikes from a fero rod. Cut up several strands of jute twine 4-6" long that has been soaked in bee's wax and pull the fibers apart where it looks like a birds nest and it lights easily. I keep about 4 different ways to start a fire in my truck and backpack. I also keep a few sticks of fatwood to use as tinder to get wet wood burning. Happy scouting.
6 years ago
has anyone ever used pine knot? it can be found wherever pine trees are located and is a natural fire starter
8 years ago
FAILURE
I CRACKED MY PYREX
THE KIDS WERE IN A HURRY
Reply 6 years ago
Did you put pyrex on your stove top?? It's not stove top safe.
7 years ago
Good idea!
I use cotton balls and/ or dryer lint covered in petroleum jelly.
Which works really well also.
Store them in zip lock sandwich bags.
Saw dust and paraffin wax make great fire starters too..
7 years ago
Awesome Idea. Thanks for sharing. I found A Great Place to find Survival Tools, resource you need to survive and thrive in any situation. I found this discount code. Use this code "PD10"and save 10%. http://patriotdeals.com/coupon
7 years ago
I'm wondering about bees wax. Has anyone ever tried this using old honey comb?
8 years ago on Introduction
I do something very similar except I save all my wax scraps left behind in tealights & other candles, which is free. But sometimes I will buy candles from the thrift store to melt down. The addition of sawdust is a great idea!
https://www.flickr.com/photos/heathashli/14009276732
Reply 7 years ago
The sawdust, egg carton, and dryer lint act as a wick. The wax won't burn on its own. Not very easily anyway. But with all that wick it should take off pretty good. Might even be able to light it with a sparker.
7 years ago
Meh, salmonella shmallmnella. They're just going to burn it not eat it. I have been using old egg cartons for more years than I would like to calculate, and I'm still here.
7 years ago
Ok I'm a Scouter, lets teach the youth to think out side the box. What about when you only have a flashlight, and a pack of foil wrapped gum and your knife on you.
Simply cut the foil wrap in 3 pcs length wise. Cut one of the pcs length wise leaving adout 1/8" in the center and leaving the ends wider. Then toutch each end if the foil to the AA battery and there you have it. The foil heats up and catches the paper on it on fire.
8 years ago
Due to a health departmentrestriction he is not allowed to use EGG CARTONS( salmonella risk, if customers touched the fire starters)
So i used square ice cube molds. i attached a super match
( Credit to another Instructable here) and attached it on the lint cube
8 years ago
I made them for a friend
9 years ago on Introduction
In general you should avoid burning chlorine compounds where you can inhale the fumes. Most of them are quite toxic. And please don't use gasoline to start a fire. It's much too volatile to be a safe outdoor fuel. Stinks, too. Both gasoline and styrofoam produce black, nasty, toxic smoke. Bad, bad idea.
Stick with candle wax mixed with lint. A little tuft of dry lint on top will light the thing just fine.
11 years ago on Introduction
These work great! I use a metal paint can and a hot plate. It takes a couple hours to melt the wax but the temp is low enough that it's not dangerous. And you can just keep using the same old paint can so there's no clean up.
Once the wax is in liquid form, I dump in my dryer lint and stir it with a long stick. Then I use the same stick to fill the egg carton. I let it dry over night and break them up. Never tried the saw dust, I will next time. Thanks!
12 years ago on Introduction
I did this a couple years back but I used only sawdust and wax and of course the paper egg carton,they worked great but are a little slow on a really cold morning now I use my torch,but you must be careful to stand the torch upright and away from stuff because it takes a while for the tip to cool.
